- is my meter running correctly?
- Smoke detector
- Circuit Breaker Lockout for Exit Signs?
- Voltage drop in underground cable
- 240V Timer Switch
- Can I use a (mistakenly purchased) 3-way switch as a single pole switch?
- 12/2 UF-B in attic?
- Elecrical Dangers: Road Worker Fatal Accident
- Loud boom and tripped breakers
- Bathroom Remodel Wiring Question
- Humming Sound from Boiler Electrical Component
- Conversion of 220 blower motor to 110
- Flourescent Light w/Motion Switch
- high voltage power distribution question
- Replace all Wiring that was Stolen any great suggestion???????????
- Double Pole Single Throw Switch
- Spdt relay
- 100 Amp Subpanel
- Joining allum nm to copper nm
- Slowing a Capacitor-Start pump motor
- Seeking Tips for House Reno. Wiring
- Making Decora Wall Plate Look Good
- Generator Safety
- Looks like we should wire with "pipe" !
- Swimming pool light
- Big Old Generac- Model 8515-0. Looking for information, parts and advice.
- RV outlet
- gfci for lighting
- Air Sealing Electrical Boxes (Expanding Foam.)
- Electric problem?
- Wall Oven connection - J-box mandatory?
- Moving Service Meter, supporting issues
- Whole House Surge Suppression
- and this is why there are codes
- Which schematic is optimal for intelligent building?
- Strange question..maybe. Combining wires from two circuts
- Dishwasher Power Cord
- Just how lazy can an electical engineer/draftsman be?
- This is why no one should ever get cocky when someone explains electrical
- Is my 240v line working?
- Dead Outlets
- Wire size, 3ph Delta, 120/240
- Questions About Wiring Shop Lights
- Back to hot docks and 2 dead kids.... dock wiring
- Acceptable way(s) to stack/bundle multiple NM cables
- Derating large conductors in attic?
- Adding a Bath Electrical Circuit
- Code Question: Safely Storing Future Use Wires
- closet light considerations
- GFCI blows on jacuzzi
- 3 way timer switch
- Whole House Lights Dimming
- Are insurers nervous about screw-in circuit breakers in old fuse panels?
- No ground wire between meter entrance and house panel
- Gap between ceiling fan housing and ceiling
- Afci & gfci on same circuit??
- Aluminium wire
- Looking for some help on garage sub panel
- KitchenAid gas stove model#KGRS807SSS
- looking to possibly install a shower light
- 2 1/2" ABS as underground conduit, Plumbers, HELP!
- Flickering Satellite feed to tv
- How to run power to a shed that is 16 inches away from my house...
- Exisiting electrical to barn and help to rectify
- Double 14AWG wiring gauge
- Simple solution for new kitchen island... ?
- A question for the trades pro
- Question for Ba9s LED Bulb
- Quick question on adding to 3 way light
- 3-way dead switch
- whole house surge protector
- Dim Glow in Incandescent Bulb When Touched
- Code question 277 and 24 volts same fixture.
- Strange ceiling fan
- Lights Flickering - bad splice in panel?
- Non-airtight 6" cans
- Wiring Bathroom Fan
- Effiency of modern tube fluorescents
- Grounding electrode/bonding question
- Square D 2 pole breakers
- opinions on what to do with house with low voltage lighting setup
- Proper way to test circuit safety
- 2 lights on same circuit controlled by 2 switches
- Fan and Switch problem
- Hooking up 240 VAC relay transformer to 24v thermostat
- Special Receptacles for Three Sets of Wires?
- Recess lighting
- Zinsco Breaker I do not recognize
- 4 Gang Boxes - Ontario
- Need help diagnosing lighting circuit
- Three phase 208Y with 120V
- Please Explain Small Gauges of Extension Cords
- Shallow Wall Cavity for Junction Boxes, Cut Back of Boxes or Surface Mount?
- Electric Code circa 1980 (grounding)
- Dimmers on 3-way
- New blogger. How to wire a fan with light?
- How to determine what kind can light
- Dishwasher/disposal wiring
- running wire in anticipation of future update
- Running 3 Wire when you Only Need 2
- What happens if I bridge L1 and L2 on a 120 genset
- Panasonic bath fan
- Transfer switch for 12v emergency lighting?
- Shouldn't Light Fixtures Have Bare Grounding Wire Connected?
- Neutral
- Outlet inside peninsula cabinet
- Help eliminating glare on worktable from overhead fixtures
- Wire Humidistat Directly to Dehumidifier
- Mobil restaurant
- LED under cabinet lights
- weird wiring and wierd voltages on 3 dual switches...
- Derating Confusion
- running hot tub from alternate energy
- Old fuse box blowing large fuses but turn on dryer and power is back on?
- Holiday wishes
- Are Heat Tapes Safe ?
- Controlling under-cabinet fluorescent fixtures with a wall switch
- hook up of table saw
- question about amps
- Oh where, oh where does that circuit go?
- Exposed NM-B in Garage... What year not legal?
- Question for nukeman
- Fuses getting very hot in Fusebox
- Electrical Question
- Power Out From Electric Space Heater
- Please Critique My Wiring Diagram
- Heat pump service disconnect
- Running Wires in Conduit inside a wall
- Overflow Cut Off Switch
- Odd Hot-Neutral Reverse after Ground.
- Lights intermittently flicker in whole house.
- Basement electrical wires
- Sunroom addition
- 110v off 220v line
- Neutral for light wired to box of 3-way switch
- Supplying 110 receptacles from 240v breaker?
- Low clearance recessed lights...
- LED Lighting Conversion
- Locking Up
- Motion detector wiring
- Opinions on quick stab connections in can lights
- Make metal glow with electricity
- breaker questions
- New electrical work question
- Running 2 Taco zone pumps off one Taco controler
- Electrical wiring in India
- Self-Contained Switches/Receptacles in Mobile Home
- UF-B or THHN in conduit for hot tub feed
- low voltage remote control dimmer
- Up grade/ retrofit lager combination service panel, delete flanges?
- Well pump electrical setup
- new bathroom wiring project
- Switched outlet
- Bad breaker or ground fault?
- Depth of cable burial for Ethernet and Coax?
- Is this subpanel wired properly?
- using copper waterlines under slab for additional ground ?
- Strange breaker story
- Switch with GFI
- Homemade egg incubator help.
- 4 Gang Switch Box Wiring diagram
- NON IC rated lighting
- Install of early warning siren
- Light Pole
- wiring a hot tub
- Help with strange light fixture wiring
- Lighting placement for kitchen/living room?
- Can neutral and ground from 50A breaker be shared
- How would I ground an internal ethernet surge protector?
- Trying to rig a variac switch to slowing raise the voltage on an old tube amp
- Retrofitting boxes in steel stud construction
- Pin Sleeve Boxes
- 16 Gauge Wire in Circuit?
- Sub panel
- How to figure out six wires and which goes with which?
- How small can my service neutral be when most of the load is 240v?
