- One zone every day, all other zones periodically?
- Suggestions for small lawn strip irrigation
- Two Valves - One Zone - Power Short
- Combining Zones & Pump Question
- Slow pressure increase
- Low Pressure on 2 heads
- Pipe Size
- Connecting one valve to two stations to get more cycle times
- Sprinkler Pipe Popping Out
- Rain Bird MV FAULT
- rainbird turf heads sticking
- All zones turn on
- 2 valves come on at once
- sprinkler
- Timer System Blowing Fuses
- Vacuum Head problem??
- Wilkins Vacuum Pressure Breaker
- Possible to build my own valve manifolds?
- Valve makes loud clacking/buzzing noise, leaks
- Pressure difference between Bleed Valve vs Solenoid
- Pump start relay switch - how to test
- Need help with Lawn Genie L2034 Adapter
- Brush In Can
- Vacuum Pressure Breaker Part 2
- sprinkler touble
- 1998 Rain Bird Image 4 - Fault
- Is it normal to use this much water all at once?
- black flexible pipe and winter
- Timer Placement
- Vacuum Pressure Breaker Picture
- Pump Start Relay (I think)
- Replacing Vacuum Pressure Breaker
- Pump start relay switch - how to install
- adding pressure
- getting rid of hammer
- Replacing Vacuum Pressure Breaker -PVC Glue Drying Time
- New pressure vacuum breaker test cocks leaking
- Sprinkler System Drain Question
- Pop Up Sprinkler issue
- New Pressure Vacuum Breaker Leak In Copper Female Fitting
- Pressure vacuum breaker making noise
- Copper Fitting Leaking on pressure vacuum breaker-update info
- Sprinkler valve doesn't appear to close
- Thank you + PVB salvage value
- Wilkins vacuum pressure breaker issue?
- Valve Help Please, Pictures Inside
- Leaking Hunter PGP rotors
- split personality?
- Valve problem on PVB
- Hose Bibb Connected to Underground Sprinker System
- Backflow preventer in crawlspace??
- filling/topping off a pond via sprinkler system
- sprinkler pressure
- Lawn Sprinkler: BackFlow Preventer, Take it in in Winter???
- Crimp or oetiker clamps
- Brass Fittings
- Watts 800M4QT blowout fitting
- Who do I call to winterize my sprinklers?
- Sealing supply pipe
- new home owner
- What type of connector do I need?
- Winterize Sprinkler, where to hook up Air Compressor?
- Sprinkler Polyethylene Piping: what is lifespan?
- rain dial timer reading short
- why would my avb dump
- installation of backflow preventer in crawlspace
- Blow-Out Question
- richdel
- Be careful when you cut roots
- Leaking Sprinkler Valve
- will this work for anti-freeze?
- Need Help Removing Impeller from Goulds JS+ pump
- Old angle valve rebuild kit?
- Rainbird valve problem
- Sprinkler for long throw application, on 4' high post
- Irrigation backflow
- Help! PVB
- No water pressure to sprinkler heads
- Toro Greenkeeper sprinkler timer PCB resistor problem
- water pours out from sprinkler turn on
- HOW TO PROPERLY Turn on your Sprinkler System
- Sprinkler zone turns on automatically
- Which way/direction does the PVB Test Cock needs to be facing?
- Help, automatic sprinkler valve not working correctly
- Rotor Heads Exposed
- PVB parts for sale
- How to turn on sprinkler pump? (novice=may be an easy answer!)
- Water coming from under bell... cause?
- Underground required?
- Hunter Irrigation Tree RZWS
- Leaking sprinkler heads
- start up question
- Water Leaking at Turn on Valve?
- Sprinkler wiring?
- Problems With In-Ground Sprinkler System -- First Time Use
- need a basic testing/troubleshooting refresher on mechanical timer
- Rotor heads are too low
- Sprinkler startup
- Replacing female copper fitting
- pressure relief valve
- PVB leaking slowly
- tips or help on unseens sprinkler system leaks....
- Irrigation system causes hot water heater to (almost) constantly run?
- gpm question
- Exposed rotor head pictures
- Repair Kit For Sale
- gravity feed calculation help !!!
- Orbit Signature Software
- Could a valve replacement cause other valves to break?
- Hunter rotor head adjustment screw
- Leak From Solenoid
- Rainbird1800 sprinkler heads along sidewalk
- Automatic line drains
- clogged intake or loss of prime
- help: parent's sprinkler system stopped working
- Zone will not shut down
- Need help identifying the brand and model number of valve
- nozzle gallonage
- Weathermatic T3 Rotor Arc Won't Adjust
- Replacing a Goulds J10S 1 hp pump for home sprinkler system
- Proline Controller
- All valves open
- Problem with Controller Relay Switch and well pump......
- Lawn Sprinkler Pump Short Cycle
- Ideas on sprinkler heads
- Hills and backflow preventers.
- combining lines with a "T"? (goal post)
- Heads have Low Flow, Pressure, Throw Distance (not sure which is correct term!)
- PWR OFF Error on RAINBIRD ESP-TM8
- Splitting a Station/Zone
- No hose clamps?
- HELP! Valve stuck in open position
- 1" Male Threaded In-line Jar-Top Sprinkler Control Valve not working right help
- Sprinkler Questions
- wet basement ... landscaping
- leaking anti-siphon valve?
- 5+ Program Controllers?
- Location of irrigation Tee and Manifold
- french drain help
- Inserting tee in existing PVC pipe
- PGP "Leakage" When Adjusting Radius
- Irrigation pump comes on but no water
- Two Questions About PVC Pipe
- Ideas for pump
- Bad threads on a hose bib
- Sprinkler Winterize, Backflow Preventer dilemma
- Mainline Repair Still Leaks
- Beginner Irrigation DIY Questions
- Old, old Toro rotor
- What gives? Rain Bird VAN Nozzles Do Not Fully Seat Into 1800 Series Sprayhead.
- Need to replace microsprays with something more rugged
- Hose/tubing for drip systems
- drip irrigation for pecans
- Irrigation injectors
- What's Better - One long session, or multiple shorter sessions?
- Is there a way to identify which pipe is which in a group of pipes?
- Existing PVC pipe a bit oval, too tight for new fitting... what to do?
- Any experience with Geyser STOP or Geyser Miser?
- polypipe
- Pvc vs copper under patio slab
- Rain Dial 600ext problems
- Garden irrigation
- Shallow Well Lawn Irragation pump cycle problem
- DIY - Drip system
- My Watts 800M4QT is leaking and I need to replace the Vent Float.....
- A little setup help!
- universities in usa with irrigation major?
- Sprinkler's will not turn on! Help!
- convert from holding tank to pump start relay
- Please help! DIY sprinkler job
- Submersible pump practical for large yards with Rotors
- Loosing Pressure
- Issue with a Hunter ASV-075 Valve..
- Outdoor faucet repair
- not enough pressure in all zones
- sprinkler timer cycling
- One jar-top valve just WON'T work!
- New sprinkler timer suddenly won't switch to 2nd zone manually
- HELP ME with this pipe size...
- Second set of valves is causing watering hammer?
- How to find leaks?
- Locating Valves
- Condensation on Backflow Preventer
- New Solenoid Always On
- Sprinkler system winterized when bought house - how to use??
- Found leaking valve I think What next?
- Removing sprinkler heads
- is it normal for water sprouting out from the sprinkler valve vent
- 24 V on all zones even when only one is on - No water on any
- Leaking Wilkins 720A PVB
- sprinklers won't turn on
- Need help with drainage in back yard
- Virtual Rain Sensor
- Pump holds prime but pressure drops to zero when starting
- Help diagnosing low pressure
- pressure system switch chatter
- Toro Jar Top Solenoid Valve Installation
- 3/4" pvc pipe seems to have swollen/expanded
- Is it necessary to turn on the sprinkler system at least once every season?
- Low pressure in one zone.
- Who makes the best Rainbird type sprinkler head?
- Hose Spigot Extender
- drip irrigation
- Rainbird SST900i won't work properly.
- Sprinkler stuck in Zone 1. Won't turn off.
- toro Sprinkler system stuck in zone 2
- Water gushing out of anti-siphon valves
- Pump cycling vs continuous operation
- small pump in stream - pressure switch? Tank?
- Moving water 600' up hill
- Cavitation
- Broke My Sprinkler System Trying to Fix it
- rain bird 1812 spray heads
- Rain Bird drip line
- repair pvc supply line immediately after pvb?
- Combining Zones
- No pressure on pop-up lawn sprinklers after replacing them
- How to tell if a pipe is pressurized
- Valve clicking, but water not flowing.
- Rotary nozzles - shorter spray length along the edge
- Nozzle that provides nozzle head coverage - and pressure regulator
- Starting design - check my flow/pressure please
- pump start relay bad? (hunter sprinklers)
- Additional sprinkler head
- Sprinkler zone not working
- Flower Bed Remote Faucet: what type of piping to use?
- Irrigation layout questions
- Question about neighbor's micro sprinkler setup -- is it really saving water?
- Yard flooding
- Sprinkler Heads
