Well water not pumping water
akkaindia
Florida
I live in south florida and i am having issues with my sprinklers for past 4 months and my water pump not pumping water at all, so i have replaced my water pump with a new one and i checked for leaks and there are no leaks either, so i start digging the line and i found the water well and it took me literally 4 days to open the cap of that well and once opened i can see water around 15 feet deep and i connected my new pump near the pump and i did test run to see if i can pull the water but no luck, i have attached the images here and you can see in one of the images water in the well, i thought there will be another pipe inside the cast iron pipe but i dont see anything, so question is what should i do in this case to be able to water pumping from the well again?
akkaindia
Florida
Never mind guys infact the issue was priming, when i connected the water hose on spigot and fill the water in the suction line and turn on the water pump and then open the sprinkler line to release air and after doing for couple of times the water started flowing as normal but found some leaks inside the pipe which i need to fix them
