Glwalters82
I have a solid shower base and tiled walls. I have had the installer recaulk the gap between the shower base and tiled wall. It lasts about 6 months and then the caulk begins to crack and the water begins to get wicked up thru the crack. There is a rubber membrane between the cement board and the framing so the water is contained and does not leak onto the ceiling below. What does happen is the water will eventually migrate to the shower door side and leak out a gap there onto the floor. As I said, the new caulk remedies the leak but eventually the caulk begins to crack in that gap and the process starts all over again. What is he doing wrong?
