Shallow well not pumping with electric pump
Kirwin727
St. Petersburg,fl
I just finished my shallow well. It is 1 1/4 in with a well point at the bottom. I have a check valve on the WellPoint attached is a ball valve to a pitcher pump. Below the ball valve is a tee with another ball valve attached to the pump.
If I close the pump with the ball valve and use the pitch pump. The well works great.
In I pitcher pump with the ball valve the pump won’t produce and water.
