plan for vertical wet venting the tub via lav in the master bath
NSB000
Minnesota
The lavatory, WC and bathtub in the master bath are all independently dry vented (original construction 1965).
But the bathtub's drain and vent are inconveniently located in a wall where I want to make some unrelated changes. So I am considering wet venting the bathtub via the lav so that I can eliminate the tub's original drain and vent pipes in that wall. This change appears to be doable.
I created an isometric drawing for the addition of the tub wet vent in the master bath.
I have done my best to ensure the changes comply with the UPC for Minnesota.
changes:
- increase pipe diameter of vertical dry vent section above lav santee from 1-1/4" to 1-1/2" to accommodate 3 DFU: lav (1 DFU) + tub (2 DFU) (table 703.2)
- increase pipe diameter of vertical wet vent section below lav santee (and above tub santee) from 1-1/4" to 2" (section 908.1 Size (for wet vent))
- insert tub santee (2" x 2" x 2") below lav santee
- increase pipe diameter of vertical drain pipe below tub santee from 1-1/4" to 2" to accommodate 3 DFU: lav (1 DFU) + tub (2 DFU)) (table 703.2)
- change direction of tub's trap arm 180 degrees, away from the wall and toward the lav drain
- change tub trap arm pipe diameter from 1-1/2" to 2" since the distance from the redirected tub trap weir to the lav drain pipe will be 4'4" (52"; greater than 42" and less than 60"), [table 1002.2]; 2" trap arm pitched 1/4" per foot
- change tub trap ID from 1-1/2" to 2" [section 1003.3]
- replace lav santee with 1-1/4" x 1-1/2" x 2"
- cap off abandoned tub santee (original drain & vent pipes to be removed)
