Rsaybe
My water softener has two drains. One of the drains is the main backwash regeneration drain line. The main regeneration drain line can be elevated into the washer drain outlet. No trouble there.
The second drain line coming from the water softener is a gravity drain line which is only an overflow line to drain away excess water should the tank fill with too much water or the appliance malfunctions.
This gravity drain line outlet coming from the rear of the water softener is 24" from the floor. The overflow drain line is suppose to end at a drain that is at least 3 inches lower that the bottom of the overflow fitting.
And my washer machine box will be sitting at 36" from the floor so I can't use this for the gravity drain line.
And I don't have a floor drain to direct the gravity drain to. This is all being setup in my garage. I'm not able to raise the water softner as I'm already working with limited space
Any thoughts or ideas to make this work?
