Voltage drops below 219? I am not feeling a cause for your symptoms. But what if something intermittently adds a resistance. That would be reflected in a lower voltage at L1-L2.I will try for that, what am I looking for (to be out of the ordinary)?
So our well is a pitless adapter type well head, do you mean to dig down to where the distribution pipe connects to the well and install a ball valve down there?with a ball valve right on the pump head
I am seeing about 6-6.5amps for the first minute or two and then it goes down and eventually stays in the 5-5.5amp range for the remainder of the 7 minutes it takes to reach 60psi.but the amps should be dropping.
