Here we Grohe again, back flow preventer stuck in valve body
Jsmallberries
Zephyrhills, Florida
Finally got around to replacing the temp/valve cartridge. There are small plastic back-flow devices on the sides, inset into the valve body.
The new valve came with replacements, so I tried to remove the old ones, since the years of hard water caused the control valve to fail.
Only part of the back-flow came out. I tried removing the remaining part with a small right angle pick tool, but can't get them out. I'm afraid of damaging the interior of the valve body,
I then turned on the water hoping they would be forced out under pressure. They are not moving.
Any advice on what to do will be appreciated. I'm stuck from moving forward.
Do I even need these devices. See photos
Neil Binda
Toronto
Try using a tool like this . This should actually help getting out the old ones out . Did you try using this tool ?
This can be very tricky . The actually control the flow of the valve and is needed .
When installing the new ones put Greese around the o rings . If you don't sometimes these parts don't go back or flush into the valve.
Jsmallberries
I was afraid of scoring or scratching the interior of the valve so I bought a non scratch pic set, it was too flexible and didn't work.
I used a right angle metal pick and filed the end flatter so it was less of a sharp point, That worked, thanks.
The calcification from the hard water really locked those ***** in there.
