Filtration setup- need some help
All Things Handy
Hello,
Looking for some advice on the orientation/order to put the filters in: Anion Treatment, Acid Neutralizer, Water Softener.
Incoming Raw Water Test
- 6.35 pH
- 0.30 Maganese
- 8.6 grains Hardness
- 0.90 Uranium
- No Iron
I am trying to figure out the order of to put the filters in. Was thinking Anion, Acid Neutralizer (since the anion lowers the pH) and then Water softener. The water treatment company is a little concerned that in this order the maganese from the raw water might coat the Anion resin (they did say i could keep an eye on it and see if the resin turns black and treat the brine tank with Iron-Out)- as a possibility.
The other option would be Water Softener, Anion, Acid Neutralizer...but then you are left with some hardness that is produced by the Acid Neutralizer...
Just looking for some advice...and opinions- much appreciated!
Thanks!!
