Accidentally cleaned sloan regal flushometer water inlet cover pipe with a brillo pad, now water slowly drips out of it
eustoma01
Guam
Any help here?
I don't have a phone on me so I cannot take photos of the actual toilet, but basically what the title says. I found this diagram detailing what the items are. I am guessing that maybe when I was cleaning the cover pipe with the brillo pad, maybe I rubbed some solder or grease off that caused the leak to form.
Basically the leak is happening where I put the red box. It's only like a small drop and not a big leak, but still needs to be fixed. Any ideas on what can be done without having to resolder anything? Is it even a soldering issue?
John Gayewski
Iowa
That is a threaded connection. Are you saying the threaded connection is leaking or is it behind the sweat solder adapter?
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Threaded joints properly made would NEVER be affected by external abrasion whatsoever.
Possibly failed/improper soldering job. The joint needs to be made up again I'm afraid and or the adapter resoldered.
