I'm trying to install a new sediment filter to replace the crappy mesh-screen filter I currently have. I just found out that the gate valve immediately following my pressure tank (I have a well) will not close completely. The net result is that I can only reduce my water to a trickle instead of shutting it dry.
The only other way I can stop the flow of water to my house is to shut off the well pump, and drain my pressure tank. Which is the ultimate fix, since then I could replace my broken gate valve. The problem is this, my pressure tank has a bunch of sediment in the bottom, and when it empties out, it makes a mess. Secondly, when I shut the pump down, I affect the neighbor who shares it.
What I would like to do is quickly cut the PVC pipe and quickly install a new shutoff valve (after the gate valve) to stop the flow. Then I can leisurely put my new filter in place.
Can someone recommend a method for QUICKLY installing a new shutoff valve. I have a solvent-style valve now. Is it possible to get this valve installed while the pipe is wet since water will be flowing through as I try to apply the cement?
Any recommendations here are greatly appreciated.
-Nick
-Nick
