Hi,
I am trying to replace the anode rod in my hot water heater but I can't find it.
This was installed new by a pro plumber 3 years ago. As part of the recommended maintentance, I was going to replace the anode. I found several online videos and it looked to be a fairly simple project.
After opening all the available "ports" on the top, there appears to be no anode.
I called the company that installed it (new owner now) and before my phone died, he said something about the anode is connected to the dip tube.
Per the documentaion I have, it's supposed to be in the rear port behind the cold water inlet. It's definitely not there or in any other available/unused port.
Also, for some reason, the pressure relief valve is located on the top of the unit vs. the side. Is this where the anode should be?
How long would you expect this to last if it has no anode?
Thanks in advance for your assistance.
