DonL
That's ok. The pump is 240V, hence my hesitation. My step-dad always taught me to respect electricity. The pressure switch is a Square D and no lever. I've changed the pressure switch in the past so changing it this time wasn't a big deal. I can't find the multimeter's instruction book, I've had it several years and honestly I don't remember buying it so it may have been given to me.
I'm unsure what you're asking about the cap. If you're talking about the capacitor, it is inside the control box so I have to open the box to test the capacitor. I looked it up online and it said to remove the wires on the capacitor and cross the poles to charge it, I did and I got a spike on the ohms.
I have already tested the circuit breaker for the pump and got 250V. So I traced the lines from there and tested the pressure switch to see if it was receiving electricity and got 250V. Then I traced the lines to the control box and got 250V at the point where the wires connect to the box. Then I checked the capacitor. That's as far as I've gotten. After that I'm not sure what to do, what to test, how to test it, etc.
I don't know if it matters but I drained all the water lines so I wouldn't have to deal with burst lines again. I do believe the pressure tank is empty as well.
Also, the pressure switch points are closed but no water.
I hope this helps. We've had no water for 4 or 5 days now.
Here is your meters manual.
www.winforce.net/manuals/GMT_12A.pdf
