Page 1 of 4 1234 LastLast
Results 1 to 15 of 47
Thread: New shower thread?
    DIY Senior Member Vegas_sparky's Avatar
    Dec 2013
    LV,NV/ Nowhere,UT
    Default New shower thread?
    The whole thread is gone. What happened?
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by Vegas_sparky View Post
    Weird.
    Not sure.
    Worked on the Ice House today.
    Maybe Jim got his "Delete Button" issued back to him? Just messaged Terry to ask what happened
    Sounds like the work of a moderator....
    Dec 2013
    LV,NV/ Nowhere,UT
    I hope the deletion was a technical error, and not a conscious decision made by the staff.
    This shower is in my own house. Its going to be my retirement home in 10 years or so. Its 250 miles from Vegas, and my wife and daughter live there full time. I make the drive every weekend. I've been working on this house for over a year. I'm exhausted, and looking forward to getting it done so I can spend more time with my family.
    I want this bathroom to be the best I can make it to be on my blue collar budget. The shower will be the focal point of the bathroom. Having it leak is my biggest fear. Of course I want to find the best system to prevent problems. This isn't a damn game to me.
    John, your comprehensive knowledge of this subject is admirable. Your expert advice is appreciated more than you know. Thanks for the help so far. You've put me in the right direction, but I'm not done yet.
    The ice house looks like it was fun just for the fact its something totally off the wall. Your kids don't forget things like that, and later in life they realize how eccentric daddy really is. Carpe Diem, my friend! LOL
    I have not had a thread delete button for years...got it one day without fanfare, and years later, it went away without notice or explanation, either. While I had it, I think I used it maybe a dozen times to delete duplicate posts, or spamming.
    Dec 2013
    LV,NV/ Nowhere,UT
    After seeing even more awe inspiring projects from the master here, all I'll say is I should put the trowel down.
    Good news is my pan holds water. Bad news is I'm using the biggest cluster$&@# of materials ever assembled. I've gone way past cowboy now, and have entered Blazing Saddles territory. That's what happens when you pick and choose methods, and techniques. Be warned all you DIY guys. There's a lot to a custom shower.
    Back to the cement board.
    Jul 2009
    North Vancouver, BC
    Last night I had a Blazing Saddle moment - about every 12 minutes like clockwork!!! lol the campfire bean scene if you remember.
    I'm glad you flood tested your job. Did all the water drain when you finished?
    Is the floor protected now from harm?
    So easy to drop something while boarding....
    When are you going to share pictures. I'll be nice.... lol maybe. lol
    Dec 2013
    LV,NV/ Nowhere,UT
    The water drained. The floor is protected.
    Here's a pic of a wall I just boarded.
    My floating toy hauler. LOL
    Jul 2009
    North Vancouver, BC
    You adding lights in those niches? IS that a two wire or four wire you got pulled?
    Any diffuser? I've been using White Laminate Glass for this step.
    I build about a 2-3" recess above the niche to house the lights, heatsink and diffuser. Are you planning something like this?
    Love the trailer! Are you allowed to keep those on in the US while driving?
    Dec 2013
    LV,NV/ Nowhere,UT
    I pulled a dedicated 18/4 Belden cable to each niche(8 total). They all go back to a controller and power supply mounted under the shower bench. I'll set them up to slow color change/fade with the upper and lower niches on different color phases. I doubt I'll diffuse/cover them at the back of the niche. If I do, it'll be a small piece of polycarb fixed over the strip. I've done plenty of wet location LED projects, and they can be amazingly reliable, even underwater.
    As far as driving with the trailer LEDs on, I've only done that twice. Once down LV Blvd for fun, and another time while on our way to go camping in the desert northeast of area 51(even more fun). Typically its illegal.
    Jul 2009
    North Vancouver, BC
    Thanks for the info VEgas
    Can you send me the info on your LED's. I would like to look more into your approach and play around with some of these LED lights.
    Dec 2013
    LV,NV/ Nowhere,UT
    I'll be happy to send you something.
    Spent the past week getting all the stuff to change my valve system. 1/2" stuff just won't cut it. Ended up with a 3/4" thermostatic valve(22 GPM), and (3) 3/4" volume control valves that will flow more than I'll ever need.
    After calling no less than 7 plumbing supply houses I finally found a 3/4" brass threaded cross tee. I wanted a copper/sweat fitting, but I'll have to take what I found. Damn things are like unicorns.
    Jul 2009
    North Vancouver, BC
    22 GPM
    What-ca-building a Car Wash? LOL
    What kind of drain you got there? You better be planning on a good 3/8" of water head above the drain with that kind of output….
    Dec 2013
    LV,NV/ Nowhere,UT
    I have used the car wash analogy talking to friends about this. LOL
    I'll only have about 11 GPM through all the heads if all the restrictors remain. I just finished getting the valves installed, flushed, greased, and assembled. Nothing is leaking. Do you guys see any systemic problems before I close this up? Body sprays are (4) x 1.5 GPM fed from valve on right.
    Dec 2013
    LV,NV/ Nowhere,UT
    Front wall is closed. I really can't believe I have to go through all this just to mastic some 4 1/4" white tile up. Sheeeesh
    Jul 2009
    North Vancouver, BC
    You didn't just say Mastic did you. Lean in closer to your screen so I can slap you !!! LOL
    Please tell me you are just trying to get me worked up….
    You are kidding right. Mastic. No _____ing way. Why not use bubble gum? Scotch Tape maybe.
    What is the water proofing measures being used over the backer board?
  1. Shower valve with male thread
    By dougeefresh in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-21-2012, 12:41 PM
  2. Please help! Leaking thread on shower valve
    By backwaterdogs in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-31-2009, 08:57 PM
  3. old shower pipe thread
    By Aristotle in forum Shower & bathtub Forum & Blog
    Last Post: 07-24-2008, 11:40 AM
  4. Shower head arm female thread - best way to plumb
    By remodelingit in forum Shower & bathtub Forum & Blog
    Last Post: 05-17-2007, 07:45 PM
  5. What is the standard thread for shower hoses?
    By murrmac in forum Shower & bathtub Forum & Blog
    Last Post: 08-06-2005, 05:02 PM
