Is it necessary or useful to insulate not and/or cold supply pipes inside interior or exterior wall cavities?
The exterior walls will have the normal fiberglass insulation between the outside wall and the pipes and some of the interior walls will have fiberglass insulation as well for noise control between rooms.
I'm wondering if condensation on cold water pipes or heat loss on hot water pipes is an issue in closed walls.
I know people commonly insulate the supply pipes when exposed in an unfinished basement. Do they only do it there (basement) because they are accessible and would they do it everywhere if the pipes were accessible?
I have the opportunity of having all my plumbing walls open now and want to take advantage of the opportunity if it is a good idea. Don't want to waste time/money if it doesn't buy me anytthing.
Joel
Joel
