Results 1 to 5 of 5
Thread: Need help replacing bathroom sink
    DIY Junior Member 14kbiz's Avatar
    Jun 2013
    NJ
    Default Need help replacing bathroom sink
    I usually don't tackle plumbing jobs on my own but I'm going to try replacing my bathroom vanity. It looks like something I can handle from the research I've done. However, I noticed something a little different about how the current waste pipe is installed. Here's a picture to help explain my concern. The grey waste pipe was installed directly into to PVC going into the p-trap. You can see where the top of pvc is expanded to accept the gray pipe. What's the best to go about installing the new waste pipe into the existing p-trap? I think the new sink will be the same height as the old one. I measured from the bottom/outside of sink drain to floor and measurements are the same.
    Thanks.
    You throw away the gray piece AND the extension below it which is glued to it. The new drain will have its own tailpiece and you will need an "extension tube" to make it longer. The extension will probably have a slip nut on it so you will not glue the two pieces together.
    Jun 2013
    NJ
    This might be a dumb question, but will the stopper assembly be in the way of the slip nut? I don't know. Just trying to analyze anything that can go wrong. That's usually my luck, it plan everything out, get so far and have a problem. I'll try the extension tube with the slip nut. Thanks for helping me out.
    The slip joint extension will work fine with the stopper.
    Do not cut the new tailpiece pipe, or at least do not cut it too short, and there will be no conflict between the pop up and the slip nut.
  1. Help!!! Single Bathroom sink to Dual bathroom sink drain
    By JayJay18 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-28-2012, 09:31 AM
  2. replacing undermount bathroom sink. Need advice
    By Roy McDowell in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-13-2010, 06:21 PM
  3. Single bathroom vanity sink into double bathroom vanity sink
    By jshaw0812 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-26-2009, 10:15 AM
  4. Bathroom sink drain leaks after replacing it
    By generalinq in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-09-2006, 02:48 PM
  5. Replacing Bathroom Sink
    By kenmist33 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2006, 11:48 AM
