I was at Home Depot yesterday and there was a Kohler toilet tank sitting out on a shelf (someone must have taken it out of the box or something). It had a canister flush valve that looked to be the same diameter as a standard flapper flush valve. They called it their "aqua piston" something.
Would it be possible if someone were to buy a new Kohler Wellworth toilet, remove the canister flush valve, and put in a regular flush valve with a flapper? Would the toilet work fine? I can just see the canister failing if someone had very hard water.
