Results 1 to 11 of 11
Thread: lengthing/moving 110V wire
    Engineer DanMc's Avatar
    Dec 2004
    Georgia
    Default lengthing/moving 110V wire
    I would like to add a recessed light, a couple in fact, in the ceiling of my 1st floor study. For a short time I have access from above because the flooring is being replaced on the second floor. The problem i have is that there is a wire, 14/2 nm, running through the joists on its way to a 2nd floor wall outlet and it would end up touching or an inch away from the can. Doesn't feel right. Replacing the whole thing would be very painful as this is an existing install and i do not plan on cutting into 2nd floor walls. Is it acceptable to cut the wire and splice in another 24 inches or so using a junction box at each end and wire nuts? That would be enough to avoid the light can. I think the wire feeds a single 15 amp dual-outlet but there may be two.
    tthanks
    AS long as the junction boxes are accessible, which I an not sure if they would be in your situation.
    What type of can is it? If it's an IC type, since that can be In Contact with insulation, an inch is more than enough. If not, then you'd have to read the spec sheet to see what the minimum spacing to other objects.
    Dec 2004
    Georgia
    Jim: they are not IC cans. The small junction box on the can is at the end of a metal bracket about 3--4 inches long. The box and bracket are an integral part of the can.
    hj: these would be new boxes. I am thinking something like cut the existing wire where it crosses a joist. Then add a junction box on each loose end one joist over. Then i would have to add a new wire between the two. I would have access because i can lift the subfloor for about two weeks before new floors come.
    Jun 2007
    North Carolina
    The boxes will have to be accessible after the new floor is installed. It isn't going to look to good with a box cover in the floor.
    I have never seen a light fixture that would be noticed if they were moved three inches away from their original point
    Dec 2004
    Georgia
    jw: ah. I understand. You are correct, to make them permanently accessible would not really be possible in this case without it being really ugly. it seems a different spot may be my only option. was trying to keep it centered relative to some windows and in the same relationship as other lights but that may just not be practical. thanks for the help. I appreciate it. Stupid question, why is permanently accessible a requirement? might stick in my head better than just remembering a rule...
    Jun 2007
    North Carolina
    Everywhere a joint, splice or termination is made is a point on the wiring system trouble can be therefore it must be done in a manner that would allow access to that point.
    quote; I would have access because i can lift the subfloor for about two weeks before new floors come.
    What about after 2 YEARS? That is when you might have problems, not two weeks.
    DIY Member Stuff's Avatar
    Mar 2013
    Pennsylvania
    Some places allow these splice kits to be hidden:
    http://www.homedepot.com/p/Tyco-Elec...6#.Uh5refZZU8g
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by Stuff View Post
    Dan,
    I have used one of these ONCE.
    I gotta say, they are engineered to a fair-thee-well.
    If you want to ask your local building dept if it is OK to use them in your plan, go ahead.
    But JW has a better idea: move the light slightly. And why not buy Insulation Contact fixtures? They can CERTAINLY be set an inch away from some NM.
    Jun 2007
    North Carolina
    They must be acessable
  1. 110v off 220v line
    By canoeboy in forum Electrical Forum discussion & Blog
    Last Post: 02-14-2013, 07:26 AM
  2. 220v to 110v
    By StatManLV in forum Electrical Forum discussion & Blog
    Last Post: 12-16-2010, 05:37 PM
  3. Sta Rite 4" 110v 2 wire Deep well Pump
    By True Blue in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-31-2009, 05:04 PM
  4. Should mains be 110v or 120v?
    By dgold in forum Electrical Forum discussion & Blog
    Last Post: 07-25-2007, 07:43 AM
  5. 110v or 220v??
    By mycard00 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-25-2006, 07:42 PM
