Thread: joining ABS pipes partially under water
    DIY Junior Member darren_t_johnson's Avatar
    Apr 2013
    Ottawa, Ontario, Canada
    Default joining ABS pipes partially under water
    Hi,
    I'm going to be joining some ABS drain/waste pipes together under my basement floor, and the bottom 1/4 of the pipe will be in water. The water table is still a little high from some recent rains. How sensitive is the ABS cement to water? I'm going to try to lift the ends up, apply the glue and join the ends... but how long should I hold it out of the water? I know it sets quite quickly... but if I put it back under water too soon, will it weaken the join?
    I've done that on ground works in Winter before where you couldn't get rid of the water. It held a test.
    You might use your shop wet-vac on it.
    Apr 2013
    Thanks Terry.
    I'll be waiting for the glue to be well set before dropping it in the whole. But its good to hear that I wont have to worry about it. Its my main waste line, so I want to leave it disconnect for too long.
    I'll be using the shop-vac as much as possible, but I can't dump it out unless I carry it up the stairs and outside... Hopefully 2 shop vacs and 7 pails will hold enough water to keep me ahead of the water.
    Thanks again!
  1. Joining Dissimilar Metal Pipes - Out of New Well and Expansion Tank
    By chuck b in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-27-2012, 09:51 PM
  2. partially blocked hot water to shower
    By peltaz in forum Shower & bathtub Forum & Blog
    Last Post: 11-23-2008, 07:43 AM
  3. 3 Stem Shower - Hot Water Causing Noise When Partially Cracked Open
    By Frayden in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-14-2008, 11:36 AM
  4. Joining vent pipes in attic
    By muzz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-22-2008, 10:46 AM
  5. Joining Pvc Pipes Inline
    By SUZY-Q in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-06-2006, 08:23 AM
