Hikermann
For some reason the cold water line-in to the washing machine has decided to get noisy; a couple of days ago it was just a bang-thump every couple of minutes when the washer was running, now it's moved to chattering non-stop (guess it's got the chills...); did the water-main-shutoff-open-everything-open-water-main business a couple of times - no solution; added a hammer arrest device at the washer intake; still chatters. Curious is that no cold water comes into the washer drum; I turn it "off" and then "on" again, which causes a minute bit of water to come in and then the "chunk" and it shuts off; hot water works fine.
Is this an intake valve or some such issue within the machine itself?
Many thanks for any help.
