Results 1 to 4 of 4
Thread: pex lines run in 2x6 wall between garage and living space
Hybrid View
    DIY Junior Member burhead's Avatar
    Apr 2013
    Iowa
    Default pex lines run in 2x6 wall between garage and living space
    I recently added a new garage with living space above it. To get plumbing to the new upstairs I had to go through a newly constructed 2x6 wall that separates the garage from the house. The lines are wiresbo pex and run in the center of the 2x6 so there is about 2.5" on either side of the line. They run through about 30' of wall and transition up into the ceiling of the garage. The ceiling of the garage is 16" TGIs and will be filled with celulose so there is little chance of freezing up there. The area above the garage is conditioned living space. My major concern is pipe installed in the 2x6 wall cavity. The garage is setup for radiant heat but that may not get done by next winter so I want to set this up to work under those conditions. I am thinking of using standard fiberglass insulation and also installing the foil (bubble wrap) on the cold side of the wall as extra insulation. Another thought was to put the split foam on the pipes in addition to the fiberglass insulation. The garage itself will be well insulated but our temps dip to 0F at times in the winter so it could be possible that the garage itself may see freezing temps. Any input is greatly appreciated.
    You want the pipes to be next to the heated wall with insulation between them and the garage wall. Adding insulation between the heated wall surface and the pipe means it won't get heat from the house...insulation doesn't make heat, it just slows the transfer, and you need it between the pipe and the cold side. Maybe some foam panels on the garage side. You could add a second layer with a slot for the pipe, open to the house side. Keep in mind, on the garage side, it needs to be fire-rated drywall...typically 5/8" thick to meet code.
    Apr 2013
    Iowa
    Ok that makes sense. I was going to use the batts with paper on one side. Typically it would be installed with the paper towards the inside. I wonder if there would be a problem reversing the insulation so that the paper was on the garage side. I know this would put the vapor barrier on the wrong side but it would keep the pipes more towards the warm side.
    In your climate, I think the vapor barrier must be towards the inhabited side. There are climates where it works better on the outside, but I think Iowa gets too cold. Foam can be upwards of 5/inch where fiberglass is lucky to get to R1-2 or so.
  1. Subpanel in attached garage adjacent to living space
    By Widgelet in forum Electrical Forum discussion & Blog
    Last Post: 05-04-2012, 06:35 PM
  2. Opening a Kitchen and Living room wall
    By Duane in forum Remodel Forum & Blog
    Last Post: 03-26-2009, 04:55 PM
  3. Positive airflow out of condensate drain into living space
    By ltm in forum HVAC Heating & Cooling
    Last Post: 11-20-2008, 08:31 PM
  4. Shower causing leaks down living room wall!
    By Cath in forum Shower & bathtub Forum & Blog
    Last Post: 08-08-2006, 09:08 AM
  5. Replacing Cast Iron Sewer Lines In Crawl Space
    By DanMcD in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-29-2006, 07:46 PM
