Hi Folks
I'm new and I tryed to replace my well pump and the pitles broke off at the top of the pipe where it connected at the pitles, how can I pull the pump?
Cheers'
zermac
If you got the pitless off and out of the way, and you can still see the drop pipe, you can put a loop over the pipe with a nylon strap and pull on that. I just wonder if your pump is stuck, which is the reason the pitless broke?
