Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Toto Soiree Lazy Flush
    DIY Junior Member hollywoodgirl's Avatar
    Jan 2013
    Massachusetts
    Question Toto Soiree Lazy Flush
    There have been sporadic lazy flushes in the past which resolved themselves. Not tonight.
    We have hard water but the Soiree doesn't have holes in the rim, there are two powerful nozzles.
    I tried a dishpan full of hot water and that went down slowly. So.
    What do you think?
    Apr 2012
    New York, NY
    Quote Originally Posted by hollywoodgirl View Post
    What do you think?
    I'm assuming I understand what a lazy flush is...it swirls around and instead of siphoning right down, it kind of wallows its way to the bottom of the bowl (but it does go). Is that it?
    Assuming that your fixtures downstream of this toilet are draining properly and thus there isn't some kind of systemic backup, I would try flushing it a few times by holding the handle down to drain the whole tank and see how it performs. Sometimes, the lazy flush occurs because it isn't starting with enough water. If that doesn't work, I would hit it with a plunger. Good rapid vigorous strokes. Could be there's a partial clog somewhere in there. If the plunger doesn't work, then a closet auger. If the problem doesn't resolve itself with one of these methods, report that back and see what The Gang thinks.
    What I'm recommending isn't necessarily the optimal solution, it's just basic Chicken Soup...can't hurt.
    One other thought is: does the toilet seem to be dropping as much water as usual through the flush valve? I get a lazy flush occasionally off what I call a "misfire". This occurs when for whatever reason the flapper doesn't cycle all the way open and shuts faster than usual. Usually occurs if I don't push the handle all the way down before releasing. The bowl gets a little water in it, the tank starts refilling, but there isn't enough water through the valve to do a regular flush, just a slow siphon to the bottom.
    Jan 2013
    Massachusetts
    Originally Posted by wjcandee
    I'm assuming I understand what a lazy flush is...it swirls around and instead of siphoning right down, it kind of wallows its way to the bottom of the bowl (but it does go). Is that it? Yes
    Assuming that your fixtures downstream of this toilet are draining properly and thus there isn't some kind of systemic backup, I would try flushing it a few times by holding the handle down to drain the whole tank and see how it performs. Sometimes, the lazy flush occurs because it isn't starting with enough water. If that doesn't work, I would hit it with a plunger. Good rapid vigorous strokes. Could be there's a partial clog somewhere in there. If the plunger doesn't work, then a closet auger. If the problem doesn't resolve itself with one of these methods, report that back and see what The Gang thinks. The tank drains completely but the water enters the bowl and s l o w l y drains and then it bubbles
    One other thought is: does the toilet seem to be dropping as much water as usual through the flush valve? I get a lazy flush occasionally off what I call a "misfire". This occurs when for whatever reason the flapper doesn't cycle all the way open and shuts faster than usual. Usually occurs if I don't push the handle all the way down before releasing. The bowl gets a little water in it, the tank starts refilling, but there isn't enough water through the valve to do a regular flush, just a slow siphon to the bottom. It's not doing this. Thank you for your time.
    Jan 2013
    Massachusetts
    PS No plunger or auger in the house, I'll call Rapid Rooter in the morning.
    Apr 2012
    New York, NY
    We generally recommend against anything with the name "rooter" in it. You're better off with a plain ol' experienced, trusted plumber. Unfortunately, Terry isn't in your area.
    Jan 2013
    Massachusetts
    Quote Originally Posted by wjcandee View Post
    I'll call the plumber who installed the toilet. Thank you.
    I would take a bucket or large cooking pot of water and pour it directly into the bowl. Sometimes that's all it takes.
    Not hot water. You don't want to melt the wax.
    You bowl is an easy fix. You can lift the bowl up, and the trapway is divided into two parts. Upper and lower.
    Jan 2013
    Massachusetts
    I just tried half a dozen times with a dish basin full of hottest water. It's not making a difference. Still slowly drains away
    and then burbles . Thank you.
    Apr 2012
    New York, NY
    So true, but her first post said that she tried that already, to no avail...
    Yakima WA
    There is probably a foreign object wedged in the trap. Small children often try flushing toys, other items like toothbrushes, combs, makeup cases, and the list goes on are often found. The won't wash out. A closet auger may work, but sometimes one has to pull the toilet and go from the bottom.
    Jan 2013
    Massachusetts
    I'll post the resolution. Hope it's quick and easy. Thank you.
    Apr 2012
    New York, NY
    Fun working with you. I look forward to learning what your plumber determines to be the problem.
    Jan 2013
    Massachusetts
    UPDATE: the plumber can't come until tomorrow, Wed Jan 9 between 10am and 1pm.
    Jan 2013
    Massachusetts
    FINAL UPDATE: the plumber who installed the Toto Soiree came a day early, he owns the company. He and his assistant spent an hour augering the toilet and siphon jets. Success. He said there could be trouble further into the line, the house went up in '68 and then I'll need to call a drain cleaning service. He recommended someone. Sound about right, gentlemen?
    If you have a partial blockage on the main line, the toilet won't flush when there's no place for the waste to go. Overnight, it might drain down, and the first couple of flushes might work right. But, take a shower, or two, and if there's a blockage, it could back up enough to then prevent the toilet from flushing.
  1. Lazy Flush
    By gotzoom in forum Toilet Forum discussions
    Last Post: 03-24-2010, 06:22 AM
  2. 1.6 or 1.2 Toto Soiree?
    By mark_g in forum Toilet Forum discussions
    Last Post: 03-04-2009, 02:18 PM
  3. Toto Soiree
    By Salmonica in forum Toilet Forum discussions
    Last Post: 02-17-2008, 10:30 PM
  4. Toto Soiree
    By ssabo4321 in forum Toilet Forum discussions
    Last Post: 11-06-2006, 06:49 AM
  5. Muratic Acid for lazy flush
    By CharlieG2 in forum Toilet Forum discussions
    Last Post: 10-23-2004, 12:21 PM
