Results 1 to 3 of 3
Thread: Salty taste to water
    DIY Junior Member TerrySB's Avatar
    Nov 2012
    Santa Fe, TX
    Default Salty taste to water
    I have a Kinetico water softener, Model #60, since 1988. I have had no problems since I bought it. In the past weeks, the water has been tasting salty, too salty to drink and use. The drain line is clean. There is a mention that the head on the resin tanks could not be working correctly.
    Can someone tell me what they think the problem can be? Can the head be changed out on the resin tanks and if so, what would the exact name of the part and part number be?
    Have you checked the raw water for the same taste? If not you should put the softener in by pass and run water to all sink faucets for a few minutes to flush the lines and then at the kitchen sink, let it run for a few minutes and taste it. Or if you have your own well and can get water from the pressure tank to taste, do that.
    If no salty taste then the most common cause of salty water is incomplete rinse, which since the drain line is not blocked or kinked should be eliminated as a potential cause, could mean there is too much salt being used to be successfully rinsed out in the length of time the rinse runs for. So is the water level in the salt tank the same as it used to be before the problem started or higher than normal? Maybe a drain line flow control button is partially blocked. If I'm right that would be inside the control valve on a Kinetico. Probably where the drain line connects to the valve. Let us know what you find.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    I have a manual and exploded view of the internal part. Just send me an e-mail and I'll send them to you.
  1. Salt Taste in Water After Regen
    By Earnie in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-10-2009, 06:52 PM
  2. yellow water iron taste.
    By bullheadpond in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-30-2008, 04:37 PM
  3. yellow water iron taste.
    Last Post: 05-30-2008, 12:14 PM
  4. Odd Taste from Water Softener
    By micahfrance in forum Plumbing Forum Discussion & Blog
    Last Post: 06-17-2006, 07:52 AM
  5. poor water taste from icemaker
    By dj in forum Plumbing Forum Discussion & Blog
    Last Post: 07-01-2005, 06:36 PM
