Kitchen drain
Lar-bear
Amherst, NY
I just purchased house and i'm remodeling kitchen. The current kitchen sink drain is 24 inches from floor to top of 1 and 1/2 inch drain pipe. My sink is 9 and 1/2 inches deep and will be mounted under granite counter top on a sink cabinet 34 inches high. Will I be ok with just 1/2 inch difference. I will not be installing disposal.
Cacher_Chick
Test, Don't Guess!
You need more room, and flexibility for future changes.
I would shoot for 15-16" off the floor to leave room for a disposal.
I think 15" to 16" is becoming the new standard too.
Without the disposer, you might be able to do 19", but for those three inches, and for a future alternate universe decision, I would do 16" and call it good.
You have 1 1/2" from the bottom of the sink, NOT from the bottom of the sind drain you will have to install in the sink. Even if you did have 1 1/2" unless you used a "low inlet trap" which are very unstable, the inlet would be above the pipe in the wall. NOTHING will work other than moving the drain line or getting a different sink.
