Thread: 1 1/2 x 1 1/4 in p-trap adapter question
    DIY Junior Member jdall's Avatar
    Jul 2012
    Michigan
    Default 1 1/2 x 1 1/4 in p-trap adapter question
    Can I put one of these on the sewer side of my trap? The one that I picked up from the hardware store doesn't have a compression ring so the 1 1/4 tube that fits into the nut does not make a tight seal.. It seems to me that gasses would have the ability to pass through this thing..
    Plumber jimbo's Avatar
    Yours is the type where the compression ring is integrally molded in the nut. If you are on the right size tube, it will seal when you tighten the nut.
    1.5" Trap adapters can be for 1-1/4" or 1-1/2" p-traps.
    If your molded slip joint nut isn't sealing, are you sure you have the right size?
    I mainly use 1-1/2" adapters, with a 1-1/2" p-trap and use the reducing slip joint washer at the top to receive the tailpiece of the lav drain.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    You have to be careful when buying unpackaged things that can be taken apart from the big box stores. Check everything to make sure it's all there...
  1. Another Pitless Adapter Question
    By mortal798 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-22-2014, 10:58 AM
  2. Trap Adapter Cap Leak
    By E-man in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-24-2012, 04:10 PM
  3. Trap adapter question
    By jwbr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-01-2011, 05:21 AM
  4. Looking for specific PVC trap adapter
    By mckeand13 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-21-2009, 04:37 PM
  5. pitless adapter question
    By cobra in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-22-2008, 07:13 PM
