Thanks for the help getting my pump back in operation. Now that Its working it doesnt take very long to pump dry. The well appears is ~ 40' deep and water fills in to about 15' feet from the surface. After I pumped it down I pulled out the pump and lowed a flash light and can see small streams of water coming in from the sides starting at about 26'. My dad said I should let it fill back up get my shotgun out, load up a slug, and fire down the well. Is this really a good idea?
bit more info:
Pumped for about 11 minutes till flow dropped to a trickle.
If I did my math right I was pumping 6.5 gallons per minute.
Suggestions?
bit more info:
Suggestions?
