Results 1 to 4 of 4
Thread: Main sewer line depth
    DIY Junior Member diganddig's Avatar
    Apr 2012
    Calgary Alberta Canada
    Default Main sewer line depth
    Hello
    I'm in Calgary Alberta and I need to replace my sewer line from the house to the property line. Current plan is to abandon the old line and trench in a new one. I'll break the basement floor and tie into the existing stack.
    How deep does the sewer from the house to the property line have to run - I'm guessing 6'.
    What about the portion under my basement floor? Can it go straight down 4' from the basement floor and then head out from there. It will be 9' deep outside the house but only 4' below the basement slab. Is that okay?
    What pitch should I shoot for - is 1/4" to 1/2" per foot about right. Is it better to add a vertical drop than to exceed the 1/2" per foot.
    Where can I get a look at applicable plumbing code to make sure I do this right? I will be getting it inspected, but I want to know what I'm doing before putting too much effort into the trench.
    Thanks for your time!
    Apr 2012
    According to a city inspector, a Calgary sewer can be a minimum of 4' from the surface provided that a proper frost box is installed.
    Next question - what's a frost box?
    Certified Plumber Plumber1979's Avatar
    Jul 2012
    Ontario
    you better check on the depth to the sewer in the street before you decide to do anything
    Yakima WA
    Plumber 1979, are you suggesting that sewage doesn't run uphill in Canada!
  1. Main drain depth exiting cottage for septic line connection
    By chuck b in forum Plumbing Code Questions
    Last Post: 06-25-2011, 01:16 PM
  2. Main Sewer line replacement
    By burin in forum Plumbing Forum Discussion & Blog
    Last Post: 12-02-2008, 04:46 AM
  3. Lining Main Sewer Line
    By Matt L1 in forum Drain Cleaning
    Last Post: 04-18-2008, 05:08 AM
  4. Lining Main Sewer Line
    By Matt L1 in forum Plumbing Forum Discussion & Blog
  5. Sewer/main line is plugged
    By jhelmich in forum Plumbing Forum Discussion & Blog
    Last Post: 03-29-2005, 11:50 AM
