Results 1 to 5 of 5
Thread: Cloudy water in well now
    DIY Junior Member Fast Eddie's Avatar
    Feb 2012
    Elizabethtown KY
    Default Cloudy water in well now
    we have had a summer home for 20 years that has a well with a plastic casing. The water has just become cloudy and has caused problems with screens on washing machines. It will clear if it is run for a considerable time...but every weekend now it is cloudy. How far from the bottom of the well should the pump be located. Is adding a whole house filter the best advise.. or what else can we do. The water was tested in the past and was 100% OK. the water has tasked great also.
    Ed
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    I would try super chlorinating the well and see if that has any effect
    Feb 2012
    Elizabethtown KY
    Quote Originally Posted by Smooky View Post
    The well is either 6" or 8" and 100 deep. how much do I add for this well?
    Ed
    Apr 2011
    NC
    I don’t know exactly how much you will need. There are formulas to determine how much. I just guess and wing it. I would use unscented Clorox bleach. I like to get the strength up to around 100 parts per million (ppm). Your well is not very deep so maybe about a quart. Put a quart into the well and recalculate the water with a hose back into the top of the well. You might have a vent and not have to remove the well seal. I use chlorine test strips from Bailey’s. After the water has run for a while check the strength, add more bleach if needed to get 100 ppm. Run the water at all your faucets till chlorine is detected. Let it stay in the well as long as possible and then run it out to remove the chlorine.
    http://stores.baileysteststripsandth...tail.bok?no=33
    Feb 2012
    Elizabethtown KY
    Thanks..... will try it this weekend
    I can leave it in all week because this is our summer house
    Ed
  1. cloudy water
    By JimIL in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-24-2011, 01:26 PM
  2. Cloudy water on new well
    By mdtireguy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-09-2011, 06:34 PM
  3. cloudy water
    By Colleen Clune in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-29-2010, 07:57 PM
  4. Cloudy Well Water?
    By JAlapeck in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-13-2008, 06:09 PM
  5. Cloudy hot water:)
    By cruiser in forum Plumbing Forum Discussion & Blog
    Last Post: 11-22-2007, 05:46 PM
