Results 1 to 3 of 3
Thread: How to Remove Temperature Handle on Delta Monitor
    DIY Junior Member wardw's Avatar
    Dec 2011
    Hines, OR
    Default How to Remove Temperature Handle on Delta Monitor
    I need to increase the maximum temperature on my older model Delta Monitor shower faucet. The Delta site describes how to set the "adjustable rotational limit stop" that's under the temperature control handle, but I can't figure out how to remove that handle to get at it.
    My faucet is an older model than the Delta site illustrates; it would have been installed in 1999 or later. It has a large Lucite volume control lever with a smaller temperature control handle forming a domed cap. There's no visible screw on it; it looks as if it can pry off, but I don't want to wreck it by forcing it up.
    Should I just bite the bullet and use a screwdriver to pry it off?
    Is there a decorative cover on the cap? Often, you can pry that off to expose a screw and then remove the cap. A picture would help. On one of them, the cap has a decorative cover that snaps onto the base portion; you pry that off to expose the screw to then take the whole thing apart. This is one reason why it is very useful to keep the installation instructions, as they show the parts breakdown and often make it easy to figure out how to do maintenace later one. If you can identify it on their webpage, they usually have the installation instructions/parts breakdown there to help you.
    You "pop" the cap off then adjust the rotation limit stop on the stem underneath it.
  1. Delta Monitor Shower handle removal
    By jakkk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-30-2011, 06:03 PM
  2. Delta Monitor Leak
    By annal_c in forum Shower & bathtub Forum & Blog
    Last Post: 07-18-2010, 11:50 AM
  3. "Sticky" Temperature Adjust on older Delta Monitor
    By sarah_pdx in forum Shower & bathtub Forum & Blog
    Last Post: 08-28-2009, 07:11 AM
  4. New Delta monitor, no water
    By hciscott in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-09-2009, 06:51 AM
  5. Delta Monitor Valves
    By Dunbar Plumbing in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-13-2006, 01:30 PM
