Results 1 to 12 of 12
Thread: Hardibacker install around bath tub
    DIY Junior Member tpacktx's Avatar
    Oct 2011
    TX
    Default Hardibacker install around bath tub
    I am installing 1/2" hardibacker cement board (Hardiebacker 500) around bath tub. I have read somewhere on other forums about leaving 1/8" gap between sheets to compensate for an expansion. However, install instructions posted on James Hardie's website only recommends leaving 1/8" gap between sheet edges for countertop and subfloor installs, and instructs not to force edges together. Nothing about leaving gaps for wall installs.
    I wonder if the 1/8" gap between boards is really necessary. The cement board appears to be structurally solid. Please share your experiences.
    Jun 2009
    Canada
    Just follow the manufacturers suggestion.
    A little space won't hurt. Further down in the instructions there's a section on using alkali resistant mesh tape on the joints. This is important, and makes the assembly more monolithic like a mudded wall. A slight gap gives a place to smush the thinset in.
    You should also be installing a vapor barrier behind the Hardie, lapped over the tiling flange of the tub and the Hardie should terminate about 1/8-1/4" above the edge of the tub deck. Since most of the flanges are thick, you can either notch the studs to make that flange flush so the Hardie can be run down over it, or stop it slightly above the flange. The bottom row of tile can overlap that area as long as at least 1/2 of the tile is supported on the CBU, which limits the size of the tile that can be used (i.e., you can't use really small tile and a high flange unless you notch the studs to allow the cbu to cover it).
    DIY Member jadziedzic's Avatar
    Aug 2006
    New Hampshire
    An alternative to notching the studs is to cut a shallow groove along the bottom rear edge of the Hardie so it sits flush over the tub flange. Notching can be difficult in alcove installations.
    That works, but notching the Hardie can be messy and keep in mind that the silica dust is dangerous when inhaled, so caution is needed.
    Jun 2009
    Canada
    Everything is dangerous when inhaled, don't be a whistle blower.
    Silica dust is a known carcinogin in the same class as asbestos...neither are a problem if you don't inhale them. If you cut Hardibacker with a saw verses snapping it, it produces HUGE clouds of the stuff - if you value your health, don't do it without understanding the ramifications and consequences. It would be hard to notch the back of Hardie without power tools, thus, the warning. One of the real cement boards might be able to be notched, but it is often then so weak, I'd not recommend it. I'd either notch the studs, or leave it above the flange and make sure I used a tile size that could handle it.
    Oct 2011
    TX
    I have installed vapor barrier - a 4mil polyethylene sheet. Hardie is cut with Fein diamond blade - not too much dust, however always cut it outdoors and wear a dust mask. Many thanks for all posts.
    Jun 2009
    Canada
    I think you'd be amazed to see what shows up on an air sample done outside in "fresh air"...
    Jul 2009
    North Vancouver, BC
    Heed Jim's advice about the Hardie Board Dust.
    The backer is a good product but the dust is nasty.
    Once the Hardie is up and the seams taped with thin set and mesh give the entire surround a couple days to cure out. Then a couple of coats of liquid membrane would be advised and you have a bullet proof installation.
    Since you have gone to the trouble to leave an expansion gap don't fill it with thin set and waterproofing. I like to tape a sliver of sill gasket before these steps and leave this in place until after tiling. Once the tile and grout are done you can slice the sill gasket back and fill with silicone.
    Good Luck.
    Share some pictures.
    JW
    DIY Junior Member Jackie G's Avatar
    Nov 2011
    Indiana
    Good Afternoon,
    New to the forum and have a question regarding the last statement John made. I have been doing lots of research before completing my tub/shower install. I have decided on the Hardie backer with a liquid water proofer (Redguard). I thought I read if using a liquid waterproofer, you should not install a vapor barrier behind the backer board. Can you clarify this?
    Thanks so much
    Jackie
    Neither tile nor Hardie are totally waterproof, but are pretty much impervious to moisture damage. So, it's not great to encapsulate the Hardie with a sealer on both sides. In case it does get wet for any reason, it would take forever to dry out - it needs a path for any moisture to be released.
  1. missing bath/shower tub vent NEW install
    By novicepiper in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-16-2010, 07:49 AM
  2. Hardibacker and tile install questions - corners
    By kjm in forum Shower & bathtub Forum & Blog
    Last Post: 02-20-2010, 05:07 PM
  3. Insulation behind HardiBacker?
    By a.y1320 in forum Remodel Forum & Blog
    Last Post: 12-13-2009, 01:50 PM
  4. Need Help with installing hardibacker
    By LadyDIYer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-05-2008, 02:33 PM
  5. hardibacker screw
    By dde in forum Shower & bathtub Forum & Blog
    Last Post: 08-07-2007, 03:13 PM
