Plumber came out and worked on electric water heater (plumbing issues). Said there were 2 issues with the round 10 gauge wire going to the water heater. Recommended an electrician (friend of his) who would come take a look for $350. Here are his issues:
1. Where the wire goes into the connector and into the junction box on top of the water heater, there is a dent in the wire. Does not look cut through, just a dent. This connector has been used for at least 10 years.
2. There is a hole in the floor where the wire comes up (we're in a doublewide home) to the water heater. The wire is pushed up against one side of the hole by the bottom of the water heater. It doesn't look smushed; it's not movable. You can't tell if anything has rubbed through. Apparently it has been this way since this WH was put in a year ago.
I know it's hard for you guys to tell much without pictures. I don't have a way to post any. But before I spend $350 on an electrician, is there any way to tell me if these are fire hazards that need to be addressed. If so, is $350 reasonable, or is this the case of I look like a female that can be taken advantage of?
Thank you so much.
Thank you so much.
