Results 1 to 2 of 2
Thread: Gas line, can I run it through cabinets?
    Plumber canton's Avatar
    Jul 2005
    Massachusetts
    Default Gas line, can I run it through cabinets?
    I'm in Massachusetts and someone I know wants to move there stove to opposite side of the kitchen. The problem is they're on the 3rd floor of a condo complex. So it would be a real pain to run up from the basement on the other side and through the two bottom apt. walls without it costing a mini fortune. The alternative is under the floor or through the cabinets which are right beside the gas line. Is this allowed, it would be through the bottom cabinets , under the sink and out the side of the opposite wall cabinet.
    Default Gas
    it is okay as long as you use the proper materials, not a bunch of appliance flexible lines coupled together.
