Results 1 to 5 of 5
Thread: Old American Standard bathtub/shower faucet leaking
Hybrid View
    DIY Junior Member Michael Carnahan's Avatar
    Oct 2010
    Seminole, Fl
    Default Old American Standard bathtub/shower faucet leaking
    I have an old 1960s American Standard single pull faucet in my bathtub/shower that has begun to leak. I am trying to remove the stem and replace it, but canít see any obvious way of removing it. I believe the series number is N1032. I found a diagram online, but it wasnít much help. Any suggestions on how to remove it, or make it stop dripping would be greatly appreciated.
    Thanks,
    Michael
    Dec 2007
    I believe once you remove the chrome tube you will start to see what you need to see.
    Personally I'd use a pipe cutter on the lines supplying it and the riser before I played with it....
    The two bolts on either side should be holding the valve together and once they are removed the valve should come apart. The replacement springs and stems will go in through the two "caps" you will find on the top, when you get it out. You should not have to do anything with the handle stem, since is it just a cam which wiggles the operating stems to open it. The springs close it.
    My mother had that valve, it lasted for 35 years, and was still working.
    I replaced all of the valves with new pressure balanced valves, but 35 years and going? I was impressed.
    Jul 2007
    USA
    That's a quality valve by a quality manufacturer if I ever saw one.
  1. American Standard shower faucet identification
    By lazybone in forum Shower & bathtub Forum & Blog
    Last Post: 07-07-2010, 05:19 PM
  2. Leaking widespread American Standard bathrrom sink faucet
    By l2s2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-04-2010, 05:37 PM
  3. American Standard Aquarian Shower Faucet ID / Trim replacement?
    By kalvnhobbz in forum Shower & bathtub Forum & Blog
    Last Post: 03-13-2010, 09:17 AM
  4. American Standard shower control leaking
    By allyner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-02-2009, 09:57 AM
  5. Leaking American Standard single handle shower faucet
    By VT Pats Fan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-20-2006, 01:24 PM
