Amtrol (digital) Pump Control Switch
chazman
Frazier Park, CA
Has anyone had any experience with using Amtrol on well pump setup ?
This product seems like way more reliable and easier to adjust (but pricey at about $160). It seems like converting from points/condenser to electronic ignition on old cars, reliability wise. But I am not sure if I can use this kind of digital switch to turn on/off my Goulds 1 hp jetpump (which is actually above the ground and pressurizes the bladder tank). I've never heard about using digital controller/switch from any of my neighbors (who all have one well/pump setup) nor from the pump guy who installed my well pump.
Please give you thoughts on this.
Here is the link. Please give your opinion!
http://www.amtrol.com/pdf/AmtrolrMC10043.pdf
Thanks.
NHmaster3015
The granite state
On the face of it, it seems like a good product but there are not enough of them in the field yet to be able to make a valid assessment as to how reliable they are. Let's face it a standard contact/diaphragm pressure switch is a pretty reliable piece of equipment and will normally last many thousands of cycles. Besides which the cost of the old standard is way way less than the Amtrol switch.
Ballvalve
northfork, california
If you wire a good quality contactor into the circuit of a normal pump switch, you would be under 100$ and have perhaps a million cycle potential.
Valveman
Cary Austin
cyclestopvalves.com
I tested some of those switches. I couldn't get any of them to last very long. They took them off the market, made some changes, then brought them back. But I think now you can only get one with a tank kit like the wellx1.
Ballvalve
Look at the previous post where the guy has a 40 year old switch still working. Oversize the contact rating on your switch for long life.
NHmaster3015
The granite state
I don't think you can either. At least I can't find the switch alone in the Amtrol catalog
chazman
Frazier Park, CA
My current switch is Square D P/N 9013FSG2M4.
Is there beefier, oversized contact rating, replacement switch for that?
Also, which website/store would you recommend for ordering pump control switch?
Thanks.
Valveman
Cary Austin
cyclestopvalves.com
Thanks.
If you are having problems with your pressure switch, you need to figure out the problem. Either the pump is cycling on and off to much, the amp load is more than the switch can handle, you have ants in the pressure switch, loose connection, or just a bad switch.
BrookeTheBuilder
Ithaca, NY
cayugacountryhomes.com
Be careful with the Amtrol Digital Control
We installed these units for a few years. The first year they were great. Suddenly, we started getting calls from clients and had a 100% failure rate. Last night I got an after hours call, 2nd failure for that client. It cost us a few thousand in emergency fixes and water cleanups and Amtrol would not reimburse us a dime. Lately they agreed to send a few of the new units, but we still have to replace them.
Be careful what you represent to the client and how you choose to warranty if you try these.
Personally, i'm checking into the constant pressure system noted in the forums, looks like good old reliable mechanicals.
Ballvalve
Motor starters, contactors, are all made the same for the past 75 years, and will continue to be so in the forseeable future.
Anyone using that electronic switch is in an unpaid research program. Mechanical pressure switches have their working parts right in your face, are incredibly reliable and can be serviced if so desired. The singular downside is ants in the contacts, which can be resolved with diatomceous earth on the box and leads incoming.
Lets not allow the pressure switch business become like the pacific rim "designers" that changes our media player types each 2 years and creates the grand canyons of defunct vcr's, tv's and dvd players.
Planned obsolescence is bad enough. Designed obsolence is a crime.
Thatguy
Homeowner
MD
If you have a DVM, acceptable contact resistance at rated current comes out to less than 30 millivolts across closed contacts. More than 100 mV = bad.
Bolted or push-on connections should come in at less than 30 mV.
There is also some kind of contact goop that lowers contact resistance but I don't know how long it lasts.
Masterpumpman
Virginia Beach, VA
www.dci-inc.us
Stay away from the new technology Constant Pressure pumps. . . they are also new troublesome technology! Consider a cycle stop valve, it's all mechanical, invented by a well driller and it works. It extends the life of your pump, pressure switch and tank bladder. It gives you constant pressure while delivering a variable flow. . .and it's simple. http://www.cyclestopvalves.com/index2.html.
NOTE: It was brought to my attention that the old and dependable Square "D" Pressure Switches have been replaced with a new version. The new version no longer has the old wire keeper for the contact points. They now have a plastic keeper and it eventually heats up causing the points to become out of alignment and in many cases fall off altogether. Beware new technology is not always better.
