Results 1 to 15 of 31
Thread: Electrical - Dishwasher hookup.
Hybrid View
    DoD Army bjferri's Avatar
    Jun 2007
    Maryland
    Question Electrical - Dishwasher hookup.
    What is the proper/standard (code) way to run the electric to the dishwasher? So far I have the wire coming out of the wall behind the sink cabinet. I kow the connection is made from within that cabinet but here are my questions:
    • Where do I set the junction box.
      • Do I make it hardwired.
        • Do I make an outlet and attach a plug to the dishwasher wire so I can plug it into the outlet.
    Thank you.
    Brian
    Jun 2007
    North Carolina
    Part III of 422 requires a disconnect for all appliances rated at one eighth horse power and larger.
    422.16(B)(2) allows a cord as long as the cord is three to four feet long and it is terminated in a receptacle that has a grounding terminal. This receptacle can be in the same space as the dishwasher or in the space adjacent thereto.
    Jun 2007
    Maryland
    You obviously didn't understand my plain jargin...lol. That being said...WHAT? Talk to me like I'm a customer and not an electrician... I appreciate your feedback but it was a little ambiguous for me not having an electical background. I just need simple terms..thank you again.
    Brian
    If you hardwire it, you need a switch (disconnect). If you don't, they allow you to attach a power cord (no longer than the code allows), and plug it in. If the description above doesn't make sense, maybe it's time for an electrician.
    Jun 2007
    Maryland
    Thanks - I understand.
    Brian
    Plumber jimbo's Avatar
    "back in the day" dishwashers were always hardwired....a plain romex just stuck out through the drywall and was connected to the jbox on the machne. Two things have changed:
    ►you are now required to have a disconnect means, which can be just plug, or a switch.
    ►many DW are now 'tall tub', and any work after you slide the machine into the spot is very difficult. I like to make all the electrical and plumbing connections outside, then feed the wire/tube thru as you slide the machine in.
    For the above reasons, I suggest putting a receptacl in a box, surface mount or conventional, and put it NOT behind the DW but in the adjacent sink cabinet.
    Jun 2007
    North Carolina
    Quote Originally Posted by bjferri View Post
    Talk to me like I'm a customer and not an electrician... .
    Well okay then here i go. hire an electrician for this installation to ensure your safety.
    Jun 2007
    Maryland
    My sarcastic humor sometimes gets the best of me. Please excuse that. I get a wealth of valuable information from this forum and all the professionals, including you, have helped a great deal.
    Brian
    Jun 2007
    North Carolina
    Then you must have wanted me to answer you with advice instead of answering you as my customer. As a customer of mine I will always be thinking of your safety and would never advise you with how to information.
    A means to disconnect must be installed. This disconnect can be a switch or a receptacle. If it is a receptacle then the cord supplying the dishwasher cannot be longer than four feet. If you chose to use a switch then the switch must be insight of the dishwasher when the unit is being serviced or taken out.
  1. Washer hookup electrical outlet box
    By DIY in forum Electrical Forum discussion & Blog
    Last Post: 06-28-2010, 09:43 AM
  2. Dishwasher Hookup Help
    By freshmo55 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-20-2009, 11:45 AM
  3. Electrical Engineer allowed to do Electrical work?
    By willijimon in forum Electrical Forum discussion & Blog
    Last Post: 03-05-2009, 05:08 PM
  4. Can I hookup a dishwasher here?
    By jeffesonm in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-05-2009, 05:21 AM
  5. Dishwasher Air Gap hookup size mismatch?
    By stinkyDavis in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-27-2006, 03:22 PM
