Results 1 to 3 of 3
Thread: Need advice on venting 2nd floor bath
Hybrid View
    DIY Junior Member adthern's Avatar
    May 2010
    Massachusetts
    Default Need advice on venting 2nd floor bath
    I have a second floor bathroom that has the typical tub, toilet and sink. Problem is there is no vent that I can see and the tub wont drain unless the toilet outake pipe is open (toilets removed). Sink seems ok, toilet and tub drain within a foot into the same line the sink is about 6 feet away and ties into the same drain line. So, it goes tub drain, tie in sink drain, tie in toilet drain (smaller pipe 1 1/2 brass I think for tub and sink-- and 3 inch PVC for toilet for sure) emptying into 4 inch PVC to CI.
    I am planning to use an AAV to solve this problem. See the pictures for a better idea of what I am facing and my plan to correct it, am I on the right track? The AAV only needs to be higher than the trap right, I mean even a couple inches would work, right?
    http://www.flickr.com/photos/50039121@N07/4651116005/
    http://www.flickr.com/photos/5003912...n/photostream/
    http://www.flickr.com/photos/50039121@N07/4651800760/
    suggestions, thoughts, advice?
    IF the fixtures do NOT drain unless you remove the toilet, you have MORE than a vent problem and an AAV would be useless to cure it.
    May 2010
    Massachusetts
    I don't understand what else could be the problem? I fill the tub with the toilet on and the tub doesn't drain (no air can get into the system), I remove the toilet (letting air in) and the tub drains fine. What else do you suggest could be the problem?
  1. Bath exhaust fan venting
    By dabiz7 in forum Remodel Forum & Blog
    Last Post: 10-04-2009, 02:42 AM
  2. Looking for advice on venting
    By mckeand13 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-12-2007, 07:51 AM
  3. Basement bath venting
    By Sirapnav in forum Remodel Forum & Blog
    Last Post: 12-03-2005, 05:22 AM
  4. venting my new attic bath
    By Don in forum Shower & bathtub Forum & Blog
    Last Post: 12-28-2004, 05:50 AM
  5. Bath fan exhaust venting
    By monkeyboy in forum Shower & bathtub Forum & Blog
    Last Post: 12-14-2004, 07:12 PM
