Results 1 to 7 of 7
Thread: AC blower starting capacitor
    Default AC blower starting capacitor
    Can a 7.5uF, 370 VAC run capacitor on my AC blower be replacled with a 7.5uF, 440 VAC capacitor? If I do, will it cause a problem? Thanks.
    Not a problem. You can go up in rated voltage but not down
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Ditto.
    The voltage rating on a capacitor (similar to the insulation on a wire) is the max supported before it could arc or short out by jumping between the insulation and the working parts. So, with what you have, you are getting a better rating.
    I understand well the VDC rating of capacitors. I have just never heard the voltage rating of capacitors expressed in therms of AC voltage before. Thanks.
    Aug 2008
    MD
    Quote Originally Posted by Bobver View Post
    AC voltage rating = "bipolar" capacitor. They have a ripple current rating because this current causes internal heating, which shortens service lifetime.
    Quote Originally Posted by Thatguy View Post
    I learn something new every day. Thanks .
