I got a shark-bite-like 1/2 ball valve. I need to cut into a copper line to place this in. The ball valve take 1 1/2 inch of pipe in each side and the ball valve in 3 3/4 inches long, so math tells me that if I remove 3/4" of copper pipe, the ball valve should fit perfectly. BUT, the way these shrk-bite connectors work is that you can only push the connector on in one direction.
Like in this diagram, the sharkbite can go on one side fine, but then how do I get the other side in? If I loosen some of the hangers, I guess there may be a little play in the pipe. Is that the way to do it, or will I spring leaks somewhere else in the line?
