JohnDavid
- Messages
- 9
- Reaction score
- 0
- Points
- 0
Looks like the only way I can vent my toilet is through the short wall I will build beside the toilet to close it off a bit from the vanities. (The wall behind it will be a pocket door and the wall on the other side is an external wall with major header at top.) The wall won't be built until after the underground work is approved. Two questions:
1) To vent vertically through the wall, can you use a tee fitting and run the two inch pipe vertically, or should a wye be used?
2) Any unique tricks to building a wall around a vertical 2" pipe?
Thank you,
John
Thank you,
John
