Results 1 to 5 of 5
Thread: Removing Compound
    DIY Member shluffer's Avatar
    Apr 2008
    Default Removing Compound
    A while back I attempted to skin coat a wall with compound. Failure would not describe the result. I have started to sand down the wall, but that is going to take forever and a day. Is there an easy way to remove the compound and start over? The wall behind it is plasterboard.
    If it was the pre-mixed stuff in a big bucket rather than a setting compound, you could try a spray bottle with just some water in it, let it sit for a bit, then see if you can scrape it off.
    DIY Junior Member Marv's Avatar
    May 2008
    Northern Illinois
    Rent a Porter cable drywall sander and vacuum. You wont regret it.
    Apr 2008
    Thanks for the advice. In the end I used my orbital sander. I was hesitant to do it, but figured I should suck it up and go for it. The wall came out very smooth. I need a couple of touch ups, but other than that I'm good. Insane amount of dust though.
    May 2008
    Northern Illinois
    With the Porter Cable there is no dust and it sands very quickly.
    You get out of life what you put into it, minus taxes.
    Marv
