Results 1 to 9 of 9
Thread: pipe coming out of concrete at an angle
    DIY Junior Member xnaron's Avatar
    Jan 2008
    Alberta
    Default pipe coming out of concrete at an angle
    The builder roughed in our plumbing in the basement. The toilet pipe is a 4" abs pipe coming out of the concrete. It is sticking up about 1.5' above the floor. The problem is that the pipe is coming out at a slight angle. It wasn't too noticeable but if I put a level on it it is out of level quite a bit left to right. I used a square on the right side and it wasn't too bad in relation to the slab (1/8" at bottom of square corner to side of pipe) but the left side looks a little worse. Is there any type of flange I can get to work with this? Should I break up the concrete around the pipe and try and straighten make it perpendicular to the floor?
    Any help really appreaciate. I'd prefer to not break up the concrete if possible but I want to do it right so I will if thats what is required.
    thanks,
    Brendin
    There's a little slop when inserting the flange into the pipe. I've not worked with ABS, but I've heard less of the ABS is softened in the joint than with PVC, so I'm not sure.
    Jan 2008
    Alberta
    Thanks...I'd like to cut the pipe flush with the floor and see if I can make it work...but if it doesn't and I need to break up the concrete the pipe will be cut at an angle and when I push it perpendicular it will fall a little below the concrete. Would this be a problem when installing the flange? or can I get flanges with deeper throats?
    Brendin
    I don't think that minor angle will be a factor. Keep in mind that these joints are 'interference fits'. This means that the fitting will be tight and may not seat until it is smeared with the cleaner and glue. Those actually melt the pipe a little and weld things together once the solvent vents off(at least on PVC - not that sure about ABS).
    Jan 2008
    Alberta
    It wasn't an issue...I cut off the pipe level witht the floor then used an angle grinder to take down the concrete at the high spots around the pipe. The closet fits nicely around the floor. Once I glue it and bolt it down it will be plub to the floor. Also the inside flush mount closet has a little play to the joint which helped as well.
    thanks
    Brendin
    Keep in mind that a toilet flange is designed to be installed on TOP of the FINISHED floor.
    Default pipe
    Glad you could make it. I was concerned about what kind of pipe you had if one side could be more out of plumb than the other side.
    Plumber patrick88's Avatar
    Sep 2007
    Webster Ma.
    Abs takes glue only and will bend alot easer than pvc. I have used pvc in the past and really like working with abs. I think it looks nicer longer and no primer to deal with. It is very common in western Mass.
    I'm just starting to work with an old friend of mine to bring solar electric and hot water systems, wind turbines, Flex Fuel Boilers, batteries, hydroponic gardening, books, pellet grills and more. Also the parts for DIY installation.
    Jan 2008
    Alberta
    Yeah I haven't cemented it into place yet. I am just glueing linoleum to the concrete floor so I don't think it will be an issue if the linoleum is or isn't under the flange as its only about 1/16" high. My plan is to put the linoleum under the flange.
    Brendin
