I'm not a pro, but I'm pretty certain the pros always use flex lines with the braided stainless steel covering.
In the "toilets" section, Cass gave what I thought was a great tip - if you use a flexible stainless steel water supply line to your toilet, use a longer rather than a shorter line, so that you can gently loop it. I would not have thought of that!
So, got me to wondering. Do the pros on this site use braided steel lines, or conventional "hard" supply lines to toilets and faucets?
If you do use flexible lines, any other great tips you'd like to share?
Thanks in advance.
Some guys take a real " old school " approach, which is fine. But the price and labor savings of the flexies are hard to ignore. And in my mind, they are light years ahead of the old integral corrugated metal valve/flex combos, which licensed plumbers all over the country installed by the millions in new construction, because they were cheap and quick. I'll take an SS flex any day.
I prefer the flexible PVC supply lines.
IMHO, they resist "knotting" and "kinking" better than the SS lines when tightening down the compression nuts.
I default to chrome supplies, flexes only get used when I have some kind of reason not to use chrome. Hard lines are a little cheaper then flex lines so it's really just the labor. Once you get the hang of bending it only takes a couple minutes to install a hard line which in my opinion it is a much more finished and professional look then a thick braided line with a loop in it that anyone with a wrench can throw on.
I started off using the soft copper chrome supplies, hated it and they are hard to remove as much as they are hard to install at times, especially when you have a really strange offset leading to a toilet. Out of all that I've seen and removed........? They all show signs of leaking at some time given the greenish corrosion at the 3/8" nut, you can tell the difference between a leak and condensation dripping back.
I've seen many of the hard ones indirectly supporting a fixture like a wall hung sink or a toilet.
I use Fluidmaster or Watts stainless steel flex supplies only, ONLY with the brass barb inserts that connect to the crimps that hold the supply lines on.
Verdeboy on those that you are using,
If those have plastic barbs holding the nuts on, they break over time and that vinyl braided plastic gets hard a freaking rock. I've replaced a few of those for splits either on toilet supplies, faucets, then leading down to washing machine hoses.
I bought them because they was cheaper but I got away from the liability.
Watts has the tightest mesh pattern of stainless steel webbing around the vinyl tubing; Fluidmaster is wider which I don't appreciate but I appreciate the quality they use on the connections and the brass barbs for the crimps.
Stainless braided isn't foolproof, but it makes for a more less time consuming task. They do make a corrugated stainless tubing but isn't popular amoung plumbers yet.
I really wish someone would come out with a 7/8" chrome brass nut for toilet supplies in flexible stainless; I don't trust plastic and those nuts break all the time on stock supplied nuts that require your own hard supply line.
I prefer solid copper tubbing but I have used flex.
I wanted to post a picture but don't see how to do it on this forum.
I have seen flex line with ss braid that blew nearly completely in two. This was a dishwasher line that flooded a kitchen on into a dining room. Big mess! It was definately something new to see for me but there it was, nearly all the way around the circumference of the ss braid was just curled back on either side as if a little bomb went off inside the line. Wish I could post the picture!
To Post a pic click on:
Manage Attachments/Browse/Upload
I tried but the file size is way too big. I'm showing my ignorance I know but isn't there some kind of way to compress the file size so that I can post it?
Check out the Brasscraft "innoflex" no one has them in my area yet, but I can't wait!
First off, yes, I use SS flex. Watts & Fluidmaster. Stay away from cheap bargin bin hardware!
To loop or not to loop? It really comes down to the distance between the stop and and toilet connection. Looping is good. A loop to tight will kink. If it looks like it will kink...adapt your application.
Copper tubing has it's applications, but typically not worth the $time$. Some Customers like the aesthetic qualities. Does on last longer? Not really. IMO, here in sunny cal, where earthquakes are a real possibility, flexibility definitely has it's pro's. Go with SS.
This is what I use:
http://www.download.com/3000-20-10607499.html
it's freeware, and a small/fast program, works great.
Master Plumber Mark:
do not hit your thumb...
__________________
Try this freeware:
http://photofiltre.free.fr/frames_en.htm
click Downloads/English Version
