Underslab DWV
gdavis62
Planning new construction with basement bath and washing machine.
Proposed arrangement of trenched-in DWV is attached. Sweeps, combos, and wyes will be used where required, and vent fittings will be rolled up at least to 45.
Do I need a backwater valve in the sewer branch that serves all the basement fixtures? If so, I can put one in the main line where noted, and have it be the type with an integral inspection and cleaning stack.
Is there anything you would change in the arrangement?
gdavis62
No ejector
The sewer lines come through the slab and the mains run under it and out to a septic tank.
