Results 1 to 5 of 5
Thread: 54x34 Shower Pan???
    Architect Spaceman Spiff's Avatar
    Salt Lake City, Utah
    Default 54x34 Shower Pan???
    Has anyone seen a 54x34" shower pan? I have one that is cracked and needs to be replaced.
    Spaceman Spiff aka Mike
    Default pan
    I am not sure if the one I have is 34" or 36" deep, but whichever one it is it will be the industry's standard.
    34 to 36 deep is fine, the problem I have is the 54 wide... I find 36, 48, & 60, but no 54...
    Default Fiberglass Pan?
    You didn't mention what kind of shower pan you have or want. I do believe I've got a Fiat 54WL that is 54 X 34 and is a molded fiberglass. Its not a gelcoat fiberglass but one that is solid in color and compression molded. If thats not what you're looking for, cultured marble and solid surface companies can make you a shower pan of practically any size.
    good luck
    Swan makes a fibreglas 54X34 pan. You didn't mention where you live. In San Diego, Dixieline has it and only one of the HD stores (Mira Mesa) stocks it. Wherever you are, a plumbing supply should be able to order from Swan.
