flazoom
I am attempting my first bathroom renovation (its a 1/2 bath) and am in a bit of a bind with installing the new vanity and sink. The new vanity is a raised model with a shelf that is 14 inches from the floor. Of course the existing p-trap is at a height of 13 inches from the floor now that I installed new tile. The pvc pipe coming out of the wall does not give me any room to install a new 'higher' p-trap unless I put a second bend that would essentially create an s-trap that will enter the wall at a 90 degree bend instead of dropping straight down. Is this an acceptable solution? My other option is to cut the wall and raise up the drain pipe to install a standard p-trap configuration. 'cutting the vanity shelf is not an option in this case. Thanks for any advise.
