Page 21 of 25 FirstFirst ... 111213141516171819202122232425 LastLast
Results 301 to 315 of 365
Thread: American Standard Cadet 3 Three Toilet consumer product review
  1. #301
    DIY Junior Member davidg60's Avatar
    Mar 2010
    PA
    Default My Cadet Three Elongated bowl 1.28 GPF - aka "The Splasher"
    Hi all,
    Just wanted to add my own experience with this model. Saying that it splashes does not adequately convey the actual behavior. To say that it erupts and projectile sprays is a bit over the top (... pun intended), but is more accurate than merely saying that it splashes. Unless there was a significant amount of toilet paper in the bowl, spray would hit the seat, the floor, the wall beside the toilet. Truly disgusting not to mention unsanitary.
    I called the manufacturer who suggested that I make sure that all of the holes under the rim were clear (they were). I adjusted they water level via the float height in the tank. I made sure it was perfectly level. All to no avail. The manufacturer said that I should return it to the point of purchase. The seller was very nice and ended upon simply issuing a credit to my charge card without even having me bring the unit into the store.
    I have no idea if the problem is due to quality control issues with this model or if there is something with my particular plumbing, but I did want to add my experience to the mix.
    For the record, the replacement unit is a Kohler Cimarron, 1.6 GPF which does not "erupt" upon flushing and is quite serviceable.
  2. #302
    Dec 2009
    northfork, california
    Sounds like the poor mans "wash-o-let" free butt and wall washing on every flush, even if cold water.
  3. #303
    DIY Junior Member coreyinoz's Avatar
    Mar 2010
    Vancouver
    Quote Originally Posted by davidg60 View Post
    Hi all,
    I found this thread after I Googled Cadet 3 splashing. After all the work of putting it in, I was dismayed to read comments like this. I guess I should have read before I bought.
    Anyway - after reading this thread, I made 2 adjustments. I didn't notice the valve not being inserted into the overflow tube in the tank... took care of that. Also adjusted the water level to roughly the bottom of the blue cap on the overflow tube.
    Doing these two adjustments made the splashing go away. In retrospect, I guess I'll spend the extra dough for a Toto next time, but at least the toilet is usable and normal now.
    As well, like several others have mentioned, I was very concerned while tightening down the upper tank and trying to reduce wobble. That rubber gasket has got to be at least twice as thick as it needs to be. It doesn't feel right reefing on a bolt that's through porcelain. I still have about an 1/8" gap between the bowl and the tank, and that's about as far as I dare tighten. However, there's not much wobble any more, so I'm leaving well enough alone.
    I have to say that my capacity for amazement was exceeded when I saw this forum and the vitriol with which people talk about their toilets. That dude Ian expresses feelings for his toilet that I usually reserve for my car, my guitar, or my wife! . I laughed out loud when I saw Terry's post satirizing it.
    The information in this thread was very useful to me, but with all due respect, I hope that this is my first and last post, haha.
    coreyinoz
  4. #304
    Mar 2010
    PA
    Quote Originally Posted by coreyinoz View Post
    I did both of these things as well, to no avail.
    Mostly for grins, I've actually listed "the splasher" for sale on craigslist (Philadelphia). Search using the terms "american standard cade 3 flowise" if you're interested. I'll be in no way offended if the moderators of this board think this reply is (in some way) inappropriate and decide to remove it.
  5. #305
    DIY Junior Member jackcracker's Avatar
    Feb 2008
    Ontario
    Two years ago I purchased a 30 year old house and started bathroom renovations shortly thereafter. Replaced existing toilets with two American Standard Cadet 3’s purchased through Home Despondent (approx $260.00 ea). All worked well for about six months when I heard water running at random times throughout the night. Since neither the wife nor I were making any midnight potty runs in our sleep,,,, and toilet training the cat failed miserably,,,,there could be only one other reason. Blistering of the flapper seal - as my fellow board brethren earlier made mention of. Marched back to HD with the offending part only to be told they do not carry AS replacements. You sell their product but do not stock replacement parts???!!!! Shopped the other big boxes to be told the same sob story. Apparently they are not permitted to sell AS replacements through their chains. (Inner voice chimes in, “I smell a corporate conspiracy brewing”.)
    Furiously dialed up American Standard Customer service,,,only to be placed on brutal ignore for almost one hour (on two separate occasions) and several emails – a fruitless waste of some choice profanity as they never responded. Finally got a lead ‘bout a plumbing supplier in Oshawa who happened to have one OEM flapper in stock. Fortunately he gave it to me as the toilet was still under warranty. WELL HALLELUJAH!!! Ordinarily you have to buy the entire flapper assembly ($15.00) as the rubber seal is only sold with the plastic flapper housing (more corporate conspiracy). Installed the new part and not 2 weeks later the second toilet starts leaking. AAARRGGHH!!! Had to wait another 2 weeks as the plumbing supplier did not have any more flappers in stock. A month thereafter and I’m in toilet heaven – no more leaks or wasting water.
    Fast forward five months and the 1st toilet starts leaking again. The dreaded blistering of the flapper seal had reared its ugly head. DOUBLE AAARRRGGGHHH!!! OOOOHHHH MY KINGDOM TO HAVE A SPLASHER problem. More “spirited” emails,,,,More phone calls to American Standard went no where as their call center obviously specialize in customer irritation. Ended up shelling out $30.00 to replace both flappers.
    Happy to report everything is fine,,,,,,,,,,,,,until this week . The DAMMMNNNN white hunk-of-junk is leaking AGAIN!!!
    After scrutinizing the box the flappers came in I finally discovered what the ultimate underlying problem has been all along:
    MADE IN CHINA
    Closing Remarks:
    (1) American Standard Cadet 3 is a great product ,,,,if you are looking to purchase a unique lawn
    ornament.
    (2) My previous 30 year old toilets were better water conservers than this 1.6l Niagara Falls.
    (3) For a “delightful” case of frustration and cauliflower ear syndrome,,,try calling American Standard Customer Service
    (4) Imho, there is more crap in this product,,,, than the "floaters" found in the bowl.
    I wouldn’t put one of these units in my grandma’s outhouse!
    Good day and good farmin’
  6. #306
    DIY Junior Member tigercruise's Avatar
    Mar 2010
    Hedgesville, WV
    Default Fill valve turns on and off.
    I think the Cadet three made in Mexico is defective. This is the second one I've had in less than 2 years and the newest one, just installed today, turns on and off during periods of non-use. I suspect it's the flapper. Flushes good but a water waster.
  7. #307
    DIY Member thebigsee's Avatar
    Sep 2009
    Southern California
    Tried over the past weekend to replace my mother-in-law's 1991 vintage toilet with an American Standard Cadet 3 from the big orange box store. Here's my summary:
    PROS: Extremely easy to find (they have them at every big box store), relatively inexpensive, very easy to install, does the job just fine.
    CONS: The tank appears to be designed with a forward lean to it, or mine was defective. It looked like it was on the verge of tipping foward, even though it was bolted down snug. It made my wife feel concerned.
    The tank lid does not sit snugly on the top, it is sort of wobbly if you touch it.
    Not an attractive toilet -- tank seems too small for the body. I have a Toto Aquia II and it is beautiful with a smaller tank. Proportions are just a bit strange on the Cadet 3.
    Worst of all -- it's designed to sit 4" from the wall. I thought I'd gotten the wrong model, like a 10" rough-in, by mistake, but I checked the install drawings and that's how it is -- with a 12" rough-in, you have a 4" gap behind the tank. Everyone who looked at it thought it looked bizarre. Again, my Toto Aquia II sits snug against the wall -- why 4" away?
    It was just too off-putting to keep, so I pulled it out, cleaned it up, packed it up and took it back. I have to say for all the grief that big-box stores get, I give BIG kudos to them for being so cool about returns. I rolled it in, the guy asked if anything was wrong with it, cut the box open to make sure everything was inside, and gave me my money back. I can only imagine the grief I would have gotten if I'd bought it from a smaller store.
  8. #308
    Think of the time and effort you would have saved if you had read the reviews on this forum...or if you did read them, if you had believed them.
  9. #309
    Sep 2009
    Southern California
    I suggested Toto right off the bat but she balked at the price -- like many people, to her "a toilet is a toilet is a toilet" and she wanted something inexpensive and more efficient from the big box store. Compared to Glacier Bay, the Cadet seemed the better choice.
    It's OK though -- after seeing this Cadet monstrosity, she warmed up to the Toto Eco Drake FAST. We ordered it and it's arriving Friday.
  10. #310
    DIY Junior Member Stu L.'s Avatar
    May 2005
    New York
    Default American Standard Cadet
    I bought and installed two elongated Cadets, one for a less used bathroom in my home and one for a rental. I bought them at the same time, at the same Lowes store for the same price, $160, including bolts, wax ring and seat. The bolts were cheap but usable, as was the wax ring in both cases. I have installed quite a few toilets and keep extra bolts, rings, replacement rings etc. on hand whereever I install a toilet. The two toilets have somewhat different flushes. In my home, the toilet has a decent flush, longer and more of a swirl type that lasts longer than the Toto flush and is very hard to clog. On the other hand, it has almost no siphon jet finish. When you piss, you just know by the flush that some is left in the bowl; it's not confidence inspiring. The other one has a bit better finish and a slightly faster flush. It's a better toilet. Parts are available, but they can't really be "hot-rodded," changing out to Korky parts did nothing for that bowl's flush. The seat is cheap and not worth replacing until it breaks as it works.
    I tend to go against the tide when the tide seems like a mob scene of followers, but in the future I know what I will do in the case of toilets. Toilets are fairly simple if they work well. The Totos do that. A toilet should be installed properly and be a fixture in that bathroom until that bathroom is demolished. Replacement parts must be available to accomplish that. My Ultramax just has that confidence inspiring flush that you either ignore or think about and be happy. The two Drakes that I put in but rarely see have as good or better flushes. If the difference in price is $200 over years of use why am I subjecting myself to irritating thoughts, much less aggravation over something that I don't have time or motivation to think about?
    I'll continue to look, just as I look at floors, windows and tiles wherever I go. I welcome any brand, most especially an American made one, being the best. In the meantime, the only decision I have to make for now is where to get the best deal on the Toto Drake or Ultramax. BTW, the new Toto seats, sold separately, IMO suck. They look nice, but you might want to drop trou in the showroom and try before you buy.
  11. #311
    May 2005
    New York
    Also, to be fair, the Cadet's 12" rough-in is perfect and the tank, installed by a knowledge person, is rock-free. They will take even tightening down to the point of contact without becoming fragile. I have a local plumber who's installed over 50 of them based on price and simple parts availability(he doesn't have one in his house).
  12. #312
    Quote Originally Posted by Stu L. View Post
    Even Toto has kinda sorta admitted that their seats arn't for everyone. They are coming out with a larger(?) more comfortable seat this year. Model # SS164 and will be standard on all the newly introduced One Piece Tiolets.
    Rob
    Sales
  13. #313
    DIY Senior Member achutch's Avatar
    Oct 2005
    Vermont
    Default Major Defect Found!! Stinky!!!
    Below is part of my post dated 04-12-2008 that refers to the defective Cadet 3 bowls. Today I found a defect in "Bowl #4" that goes beyond cosmetic which I consider serious.
    We have been noticing a foul odor like stale urine that seems to be coming from inside the toilet bowl (not on the floor or anywhere else -- both of us have good noses). Until now, I have NEVER had a toilet that smells. This morning, after I noticed that the smell had gotten worse, I took a hand mirror and looked underneath the rim. See attached photos of the separation of the glaze between the rim and the bowl. I believe that this may be where the odor is coming from.
    While the toilet performs well (never a clog or a leak), a stench is unacceptable. We're giving it another good scrubbing with bleach, but my guess is that it will be going out the door and replaced with a Toto like the one in the main bathroom.
    achutch
    The bowls, all made in the US, had quality issues.
    The first bowl rocked because of a slight projection on the bottom between the horn and the front part of the base that hadn't been trimmed, UNACCEPTABLE. That one was returned.
    The second bowl didn't rock and the projection was trimmed out. However, there was a gross imperfection of a seam inside the bowl at the bottom where the water goes out which had been permanently stained blue (fired in), UNACCEPTABLE. So in late afternoon during rush hour, it got returned. I, now quite cross, informed the person at the return desk that I expected a rep from the plumbing department to meet with me, and together we would inspect every Cadet 3 bowl until I found one that was acceptable.
    After looking at another bowl and finding a flaw in the glazing in the same area as bowl #2, the plumbing rep brought down a pallet of Cadet 3 bowls. Luckily, the first box he opened contained an acceptable bowl, though not flawless. Bowl #4 was brought home, is now up and running, and to its credit, it works well.
  14. #314
    Jul 2007
    USA
    I simply cannot believe a fine bit of American porcelain would do that.
    Did you hit it with something heavy by mistake?
    Or was there an earthquake perhaps?
  15. #315
    Dec 2007
    Quote Originally Posted by Ian Gills View Post
    Or, Perhaps a quality control inspector on siesta?
  1. Replies: 360
    Last Post: 02-15-2014, 12:08 PM
  2. American Standard Cadet 3 Toilet Flush Problem
    By Retired2006 in forum Toilet Forum discussions
    Last Post: 11-03-2013, 01:32 AM
  3. Replies: 12
    Last Post: 10-02-2011, 11:08 PM
  4. Eljer Titan toilet product review, Rated #1 by Consumer Reports
    By Reader Review in forum Toilet Forum discussions
    Last Post: 04-18-2011, 06:32 PM
  5. Replies: 25
    Last Post: 12-12-2009, 09:47 AM
