Tickridgescott
I have a relief valve (75 psi) hooked near my pressure tank. I want to know if I can plumb it directly into the waste line. Someone told me that it may introduce bacteria into the potable water system.
I have a central drain located on the floor of the utility room several feet away from the pressure tank. I thought about running a small pipe across the floor and drill a hole into the drain grate and point it downwards. I also am going to have the pressure relief from the hot water heater hooked to this as well.
Any feedback?
thanks,
Scott
Any feedback?
thanks,
Scott
