Terry, OUCH! I'm glad you're ok and that you were able to get it sorted. I injured my rotator cuff, deltoid, & bicep on my left arm. I can barely use the stupid arm and I can't lift it even 90°. As a result, I have a harder time washing under that arm and developed a rash. I can't reach behind me and can't reach very far across my body with the stupid thing. Shoulder seems frozen below a certain position-- even if I try to pull it up with my other arm, it just stops-- won't go any further. Bicep constantly throbs. No idea how I even hurt it, but I just recovered from injuring the other rotator cuff & deltoid.
Some of the insulation on my outside hose bib (used for a water trough for the cows) had peeled off and the pipe burst in the cold. We usually don't get below freezing weather but the last few winters have been colder. It's rare to get under 40°F but we had 2 days where it didn't even warm up to 40. The hose bib happened to be one of the few ones without a shutoff (no idea why). So I had to add one. But I had to wait for it to warm up enough for the PVC cement to work bc the All Weather stuff is not available within 100 miles. I'm on a well system but even with the power to the jet pump shut off, the water will still flow through the pipes without a shutoff valve being turned. So, my fat monkey behind tried to turn the shutoff valves inside the pump house. They were jammed (one to the house actually had a wing break off the shutoff valve). Since my shoulder is borked, I couldn't really bush with my left arm enough. I ended up losing my balance and falling on the PVC pipes and breaking them. I hit 1 pipe but it took out ones it was connected to. Upside was water stopped flowing out of the hose bib pipe so I was able to put a shutoff on it. But, one of the pipes broke off underground and was under a cinderblock. I had to have my friend come out Christmas day to fix it. It's a temporary fix bc my outside waterlines are not hooked up for now. Going to run PEX to them later.
I really need a more efficient system with more stainless steel & less PVC. And I need to figure out what to do about my shoulder. I don't have insurance so I can't get an MRI (in my state the only way to get an MRI is with insurance approval-- no insurance, no MRI). Without an MRI they can't diagnose-- not that I would be able to afford treatment anyway. So, I have to keep doing the shoulder exercises and hoping it will heal.
Meanwhile, I'm still trying to plan out how to fix up my shower. Needs new shower walls, patch to the tub (can't tell if its porcelain or enamel), new shower trim, etc.
